cylinder vertices
cylinder vertices
Hey forum.
How can I get vertices on the top side of a cylinder?
I insert into my stage a cylinder and I can only seem to add around
the body but not the top side?Its the only option I have in my Mesh Tools
which are:
Vertices
Radius
Depth
thank you.
which are:
Vertices
Radius
Depth
thank you.
One way to do it is to loop select the top edge using alt click, excrude and scale it down a bit so you can see your new verticies, Then with the excruded edge still selected go to the tools at the left and select merge at center. This will close off the end.
You really don't have to scale it down, it just helps as a reference. When I first stsrted using blender I had a lot of issues with double verticies because I would excrude and think that nothing happend because the verticies were on top of each others.
hope this helped
hope this helped
Same problem sort of
Hi im new to the forums and blender, got blender 2.66a 64bit for win 7 64.
Any help would be appreciated.
I have the same problem, i load a cylinder and the top vertices are missing from the middle of the top?
I remember the other day these top vertices where there, i remember deleting them in a tutorial i was doing. the vertices converged on the top like slices of cake (technical stuff)
I load a cylinder add mesh/cylinder
then in "edit mode/wireframe" i look at the cylinder top and no vertices converging in the middle, i remember them there the other day because i had to delete them in the tutorial.
Now if i go back into "object mode/solid" i cant see through the cylinder?
The work around by j kaulfers is helpful, i "alt/righ"t click on the top vertices so they are all selected, then "E" for extrude, Hit "Enter" then click "merge/at center" from the left menu and now i have the cylinder top i had the other day.(slices of cake)
I can now delete these top vertices and see inside the cylinder but not all the way through? i have no converging vertices on the bottom either
I would really like to know why the cylinder has changed the vertices on top (converging like slices of cake) when i load the cylinder up. Why now have they disappeared?
I have done a full "Un-install" and re-install
I have done file/new/load start-up file
I have tried file/load factory settings
Any help appreciated and i hope this is in the right place
Yes that's done the job, thank you very much, i don't like to work around something, i like to know why and how to fix it and you have sorted it.CoDEmanX wrote:When you add a cylinder, you can change the type for cap filling in the redo panel, none / ngon / tris fan - does that help?
I did try a forum search and as i say im new to blender....so far i absolutely love it!!!!
It would probably of took me ages to find that out by myself, now time to try and read up on the differences.
Thanks again!!
You're welcome
"Nothing" is obviously not filling caps, so no face(s) at the top and bottom
"Ngon" fills the ends with one face each, these faces will be polygons with multiple vertices (if your cylinder has 24 verts for the circle, the polygons will have 24 verts each too)
"Triangle Fan" fills the ends with triangles (faces with 3 vertices), with a vertex in the center. You then see this in wireframe mode or if you enter editmode after you added the cylinder.
The "Ngon" looks the same to me as the "none" in edit/wireframe and this is what confused me. I have loaded 3 up "nothing", "ngon", "triangle"....pulled the vertices on each and gone solid to see the differences)
Im getting there sloooowly but surely.
Its a good job i didn`t just go with that workaround or i would have been doing things wrong and scratching my head with a "why does it look like?"
thanks for that
One day i hope to have blender enlightenment!!
thanks for that
