make invisible plane for shadow only?
zedeneye1
Post by zedeneye1 »
I am camera tracking. Have setup a wonderful track. And added an object. Now how to cast shadow? I need a plane that is invisible otherwise but shows shadows. so how do I do it?
thanks.
zedeneye1
Post by zedeneye1 »
Also I need to know why the background image is not rendering ?
I have a movie set as background but it doesn't render. How do I do it?
mooncaine
Post by mooncaine »
Just saw your question about invisible shadow planes. I had the same Q, and found an answer here:
http://blenderunderground.com/forums/vi ... f=2&t=3821
I'm using version 2.66. The tip didn't work for me exactly as described. To render objects & shadows without the background, I must also change a setting in the Render Properties panel, in Shading: check the Ray Tracing box and choose "Transparent."
The render still has a faint dark tint across the entire 'empty' area, as if there were 1 huge, dim shadow cast on everything... but I'm close. When I get rid of that shadow/darkness, my objects will be rendering with shadows, but with no visible background.
I don't know why the background movie isn't rendering (I've never tried that), but if you can render the front layer(s) with your shadow-catching plane, maybe you can composite that render on top of the background movie that isn't rendering.
mooncaine
Post by mooncaine »
update:
I also had to go to the plane's Materials Properties panel, check the Transparency box, then set Alpha (in same panel) to about .50, and click "Raytrace."
The number .50 seems to affect how dark the shadows (and the supposedly invisible shadow plane) will appear in the final render. It needed to be greater than 0 but less than 1. Maybe it'll need tweaking.
My goal is to have a background that exactly matches the blue of a web page that will hold this embedded video.
