array acting different after zooming in to mm/inch
I'm using the array to make a circle of objects.. it works fine (using default size) then I zoom in and use actual dimension (mm/inch).. and the objects get smaller (or larger) as they are added to the scene.. What am I not doing correctly? is there a tutorial I can watch? Also when I rotate in Z axis the objects spiral up....
