Question : Simple lattice animation of a cube
Posted: Wed Apr 17, 2013 6:01 pm
Hello,
I found a small easy tutorial about animating a lattice to shape a cube. It is easy and I have no problem with it. I also saw that I can combine 2 shape keys to merge the animation but the issue is I can't shape it like I would like because the shape I make must be on the cube (without any change).
I'm trying to make a simple test, have a small cube make it big (easy for now) and then add a roof. Nothing fancy, a simple pyramidal roof.
The issue is here : When I make the roof on the small cube it won't be as I want once the animations to make the cube bigger are done.
Look :
Shape key (roof) :
Final shape (all the key merged) :
What is my mistake ? Or should I use another way to animate it ?
Best regards,
rXp>!<[/img]
Look :
Shape key (roof) :
Best regards,
rXp>!<[/img]
