Problem inserting keyframes on field of view
alex0091845
Post by alex0091845 »
Hi guys:
I have this problem in my FPS game where I want to change camera's FOV but it just kept going back to what it was before. I tried to insert keyframe of the FOV but it doesn't have the option of "insert keyframe". The first thing I saw when I tried to insert a keyframe on the FOV is "Reset to Default Value". I tried that and it still doesn't work, help!! (please!)
Alex
CoDEmanX
Post by CoDEmanX »
you can't animate the fov, but if you switch to focal length, then you can! Or animate the sensor size.
alex0091845
Oh
Oh I meant that (focal length), I'm just used to say "FOV", sorry about that. But I still can't! I tried a several times and it just wouldn't work...
Alex
CoDEmanX
Post by CoDEmanX »
works fine here, does the background of the field change when you insert keyframe?
alex0091845
Not sure
I'm not sure what you're talking about, and by the way, it just says Field of View, where's Focal Length??
Alex
CoDEmanX
Post by CoDEmanX »
change the Lens Units from Field of View to Millimeters in the dropdown next to the FOV / Focal length field. Then FOV will turn to focal length, and that field is keyframable
alex0091845
Oh~~
Oh that's where I had problem on, thanks~
Alex
