Rotating a group of objects
dudo5611
Post by dudo5611 »
Hi, I wanna ask for help... I`m trying to rotate a group of object... I want to rotate them by eg. 45 degrees...
When I use R key it`s working, but by that way I cant to rotate by exact angle eg. 45.5...
When it`s just one object I can pres N and then modify rotation "coords" but when I do this with group of object it modify only one of them, not all in group...
Can you help me with this? Thanks
farbw3rk
Re: Rotating a group of objects
Post by farbw3rk »
use the "R" method. select your objects, hit "R" and type "45.5" on your keypad.
dudo5611
Post by dudo5611 »
farbw3rk wrote:use the "R" method. select your objects, hit "R" and type "45.5" on your keypad.
Wow thanks, that works.
