Nurbs mesh tools in edit mode doesn't work ?!
guizmann
Post by guizmann » Thu Aug 08, 2013 10:47 am
Hello !
It's impossible for me to select hedges or faces in edit mode with Nurbs (surface curve). The shortcut ctrl + tab which activate the selection tools works for mesh but not for nurbs. I'm using v2.6 of blender.
it seems to be possible when i see this : http://www.youtube.com/watch?v=p1xDvnVovd4
Is there any way to merge geometries too ? because alt + M doesn't work.
Any ideas ? Does i have to add lines code or something ? Is there some version of blender in which it works ?
Thank you for your help.
