Merging two edges with different number of vertices
LaurentR2D2
Post by LaurentR2D2 »
Hello,
How should I do to merge two edges with a different number of vertices on each ? I'm trying to merge point by point, but is quite a tedious task (I have to choose which one I can merge, and if I make a mistake I have to start again), so it would be nice if there was some simpler way :)
Thank you
brasshat
Post by brasshat »
I'm afraid vertex by vertex is the only way to merge, as merging works at the vertex level. An edge is a set of two vertices, and trying to merge two edges would result in merging all for vertices to a single vertex.
However, if you you have toe start over when you make a mistake, you may want to modify your workflow slightly, be examining the result more carefully as you do the merging operations. Then, in the event of a mistake, you can use the "undo operation" [CTRL-Zkey", and undo just the mistake.
ns
