Problem with object selection in Object mode
LaurentR2D2
Post by LaurentR2D2 » Sat Aug 17, 2013 7:44 pm
Hello,
I've made a house with several linked parts. I'm adding another part which I haven't linked to the others. When I'm in edit mode, I can select it and do what I want with it. When I'm in Object mode, I can't select this object alone without having the linked ones selected too. What should I do, please ?
Thank you
stiv
Post by stiv » Sun Aug 18, 2013 2:27 am
You added the new part in Edit mode which makes everything one object. Use the P-key to seParate selected parts in Edit mode.
LaurentR2D2
Post by LaurentR2D2 » Sun Aug 18, 2013 1:29 pm
stiv wrote:You added the new part in Edit mode which makes everything one object. Use the P-key to seParate selected parts in Edit mode.
Great. Thank you :D
