Export mesh with rigging and amature.
lebronfilms
Post by lebronfilms »
Hey guys,
Admittedly, I'm not very competent on Blender. However, I was wondering if there's a file format that will allow me to export mesh/tex/armature/rigging data. Which I can then import into another Blend.
Exporting with 3DS-Max, I use OpenCollada .DAE, which imports into Blender perfectly. However, I need a similar format for Blender which can export then import armature/rig data.
Thanks in advanced!
LBF
lebronfilms
SOLVED
As soon as I posted this, I then found a solution. I've never actually noticed the "Append" feature before. But it works great.
