Idea on windows' header selectors flips (bottom and top)
S.D.R.A.
Post by S.D.R.A. »
Hello,
I have just transferred from 3ds Max to Blender, so I am experimenting on the interface layout and all that.
My question is: is there a way to save the preferences for flipping to bottom or to top the element described in the subject, for "comfort's sake"?
Because I haven't identified this in user preferences > input > header.
The only solution I have found to solve it is to save the disposition of the selectors (all flipped to bottom in my case) by saving the file, and when I open a new file, the properties window and the other one (there are two on top as far as I know). But this is file-dependent. If the option doesn't exist in user preferences, wouldn't it be nice to make this little change?
For the text editor, I agree it should stay file-dependent.
I hope my idea is right for a first post in the community...
stiv
Post by stiv »
Start Blender, which opens the default file.
Make your changes.
Click the Save User Settings button in User Prefs
S.D.R.A.
Post by S.D.R.A. »
I know Blender very well, I am at 1,5% of my learning book.
Now 1,9% of the book.
The process for doing this is nearly how I expected.
File > Save startup file.
And when I create a new file, it keeps all the changed configuration (flipping and notes in text editor), and the little change to the default cube.
The only solution as far as I am to go backwards is to load factory settings. But this is completely factory.
I would have liked to find a way to restore a previous user settings config file, different ones in a history of backups, like the restore points on Windows.
But nevermind, it's perfect.
