Emit Light Shadows
zetulaj
Emit Light Shadows
Post by zetulaj »
Hi, I have a quick question about objects that emit light, namely, how do I get it to work with shadows. Here is a screenshot, which should illustrate my problem:
As you can see, the cube is emitting light using the "Approximate Gather" method, however the sphere should be casting a shadow, but it is not. All the other materials are at default settings. Where is the setting that enables the shadow? Thanks.
