if render again in directly, sometime the result is sky only
zieplie
Post by zieplie »
sorry for my bad english :(
I render any object with different layer and the object rendered is well as usual. But when I directly render again the result is blank (no object rendered) only sky or background only (if I use background image in nodes).
when I back to 3d view then do any work but wihout any edit, like change camera view only then I try to render again the result return well again. and when diretly render again (f12) it will blank again, and sometime camera render view (render result) change on different camera
help me to fix this problem, please :cry:
BLENDER INCREDIBLE
