How to distort buildings from Open Street Map .OBJ
Johnv
Post by Johnv »
Hello,
I'm working on a project and I've been stuck for months. I've watched many tutorials but I cannot find a solution.
I downloaded a map from OpenStreetMap and then using OSM2World I converted it in a .OBJ file.
I imported this map in Blender and now I need to modify the buildings, some should be taller, others should disappear, etc...
I need to modify a lot the map, and it can be even random in some points.
This project is about architecture, but not realism.
I cannot find a way to modify the data...
The map is like one single object, and I can't select a single house.
What can I do?
Thank you very much!
stiv
Post by stiv »
Edit mode:
select verts and use P-Key to seParate them.
Johnv
Post by Johnv »
stiv wrote:Edit mode:
Thank you very much! I'll try!
