Blender memory guarded allocation (mallocn.c)
mjordan
Post by mjordan »
Hi!
I'm trying to figure out how the guarded memory allocation works in blender. I'm reading the code inside mallocn.c and I'm struggling against the meaning of two defined macros.
The first one, MAKE_ID, for big endian machines, is defined as:
Code: Select all
MAKE_ID(a, b, c, d) ( (int)(a) << 24 | (int)(b) << 16 | (c) << 8 | (d))
while for little endian machines it's defined as:
Code: Select all
MAKE_ID(a, b, c, d) ( (int)(d) << 24 | (int)(c) << 16 | (b) << 8 | (a))
I can't undestand the "semantic" meaning. Is this a sort of hashing? They give the same results for little and big endian machines? Also, why only the first two parameters are casted to int? What is the logic behind this?
The second defined macro:
Code: Select all
MEMNEXT(x) ((MemHead *)(((char *)x) - ((char *)&(((MemHead *)0)->next))))
My C knowledge can't permit me seeing what it means... Please explain me ...
Thank you in advance...
Regards,
Renato Perini
You can't live with women, you can't live without women.
Fuzzy logic example.
