Linking problems with scons
alarionfirn
Post by alarionfirn »
I'm under windows and using MinGW with scons to compile blender. However when linking blender.exe I'm getting tons of undefined reference errors.
Linking program ==> 'blender.exe'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0xbe): undefined reference to `__gxx_personality_sj0'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0xe7): undefined reference to `operator new(unsigned int)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x132): undefined reference to `operator delete(void*)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x1bb): undefined reference to `__gxx_personality_sj0'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x279): undefined reference to `operator delete[](void*)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x29c): undefined reference to `operator delete[](void*)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x67e): undefined reference to `__gxx_personality_sj0'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x6a7): undefined reference to `operator new(unsigned int)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x6e8): undefined reference to `operator delete(void*)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x891): undefined reference to `__gxx_personality_sj0'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x95a): undefined reference to `operator delete[](void*)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x964): undefined reference to `operator delete[](void*)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x974): undefined reference to `operator delete[](void*)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x97e): undefined reference to `operator delete[](void*)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0xe3c): undefined reference to `std::ios_base::Init::Init()'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0xe58): undefined reference to `std::ios_base::Init::~Init()'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_C-api.o):SND_C-api.cpp:(.text+0x16f): undefined reference to `operator delete(void*)'
C:\blenderdev\trunk\build\win32-mingw\lib\libbf_soundsystem.a(SND_SoundObject.o):SND_SoundObject.cpp:(.text+0x12): undefined reference to `__gxx_personality_sj0'
....etc.
collect2: ld returned 1 exit status
scons: building terminated because of errors.
Does anybody know what causes this problem?
jesterKing
Site Admin
Post by jesterKing »
Looks like the stdc++ library is missing. Check your mingw install and also check if you accidently changed the win32-mingw-config.py
/Nathan
alarionfirn
I have the stdc++ library and I checked that I didn't change win32-mingw-config.py. Everything seems to be fine.
Thanks for your quick reply though :) .
harkyman
Post by harkyman »
This is where I'm at as well. Exact same problem. Smooth compile until that final linking stage. :cry: I also have the mentioned lib sitting quite happily in mingw.
Scons .97 and .96 -- both give the same result.
gcc and g++ 3.4.2 (mingw-special), which others on IRC have reported success with.
Windows XP.
jesterKing
Site Admin
Set LLIBS in your user-config.py to include stdc++ as follows:
LLIBS = ['-lshell32', '-lshfolder', '-ldxguid', '-lgdi32', '-lmsvcrt', '-lwinmm', '-lmingw32', '-lm', '-lws2_32', '-lz', '-lstdc++']
/Nathan
scabootssca
Post by scabootssca »
oh cool thank you jesterKing, i had the exact same error and couldnt get blender to compile and now it's working, so thanks alot
jesterKing
Site Admin
Since this has for some reason popped up lately I'll commit this addition to the default settings for mingw.
/Nathan
jesterKing
Site Admin
Done.
/Nathan
ChristianDobryvechir
Re: Linking problems with scons
Post by ChristianDobryvechir »
[quote="alarionfirn"]I'm under windows and using MinGW with scons to compile blender. However when linking blender.exe I'm getting tons of undefined reference errors.
....etc.
The problem is in linking standard libraries, however, if you use g++ instead of gcc you will not have these problems.
May God give you wisdom!
Christian Volodymyr Dobryvechir (dobrivecher at yahoo com)
stiv
Post by stiv »
May God give you the wisdom to not reply to 3 year old posts.
He might further note the problem referred to was a missing libstdc++, not the wrong compiler.
