Compiling latest SVN on OSX intel
el_diablo
Post by el_diablo »
I have a small problem compliling on OSX.
Code: Select all
Compiling ==> 'buildinfo.c'
Linking program ==> 'blender'
/usr/bin/ld: warning -L: directory name (lib/darwin-8.x.i386/iconv/lib) does not exist
/usr/bin/ld: Undefined symbols:
Imf::Channel::Channel(Imf::PixelType, int, int)
_libiconv
_libiconv_close
_libiconv_open
_locale_charset
_libiconv_set_relocation_prefix
collect2: ld returned 1 exit status
scons: *** [/Users/igor/Documents/Work/blender_dev/source/build/darwin/bin/blender] Error 1
scons: building terminated because of errors.
I dont get iconv headers/libs with svn checkout of darwin...
The problem is prolly something basic, but I thought I might get it solved here sooner than my own tinkering.
stiv
Post by stiv »
Don't know about iconv, but the Imf stuff comes from OpenEXR.
From the warning msg, something looks broken in your settings. The -L: directory name (lib/darwin-8.x.i386/iconv/lib) should have a full path and not start with lib. (if I'm not mistaken. not an osxer)
Jens
Post by Jens »
Hi Igor
As far as i know, iconf is not in the LIB but resides in OSX.
But compiling should be no problem, i do it succesful with
the following configuration, no x-tra dependancies nessesary.
It´s configured for building against Python 2.5 !!!
To use it with Python 2.3, change the lines with:
BF_PYTHON_VERSION = '2.5'
if BF_PYTHON_VERSION=='2.5'
to 2.3
and the path :
/Library/Frameworks/Python.framework/Versions/'
to
/System/Library/Frameworks/Python.framework/Versions/'
Here is my always working darwin-config.py, just copy
the text in yours:
LCGDIR = '#../lib/darwin-8.x.i386'
LIBDIR = '${LCGDIR}'
# enable ffmpeg support
WITH_BF_FFMPEG = 'false' # -DWITH_FFMPEG
BF_FFMPEG = LIBDIR +'/ffmpeg'
BF_FFMPEG_INC = '${BF_FFMPEG}/include'
BF_FFMPEG_LIBPATH='${BF_FFMPEG}/lib'
BF_FFMPEG_LIB = 'avformat.a avcodec.a avutil.a'
WITH_BF_VERSE = 'false'
BF_VERSE = "#extern/verse/dist"
BF_VERSE_LIBPATH = "${BF_BUILDDIR}/extern/verse/dist"
BF_VERSE_INCLUDE = BF_VERSE
BF_VERSE_LIBS = "libverse"
# python.org libs install in /library
if BF_PYTHON_VERSION=='2.5':
BF_PYTHON = '/Library/Frameworks/Python.framework/Versions/'
else:
BF_PYTHON_INC = '${BF_PYTHON}${BF_PYTHON_VERSION}/include/python${BF_PYTHON_VERSION}'
BF_PYTHON_BINARY = '${BF_PYTHON}${BF_PYTHON_VERSION}/bin/python${BF_PYTHON_VERSION}'
BF_PYTHON_LIB = ''
BF_PYTHON_LIBPATH = '${BF_PYTHON}${BF_PYTHON_VERSION}/lib/python${BF_PYTHON_VERSION}/config'
BF_PYTHON_LINKFLAGS = '-u __dummy -u _PyMac_Error -framework System -framework Python'
WITH_BF_OPENAL = 'false'
#different lib must be used following version of gcc
# for gcc 3.3
#BF_OPENAL = LIBDIR + '/openal'
# for gcc 3.4
BF_OPENAL = '#../lib/darwin-8.0.0-powerpc/openal'
BF_OPENAL_INC = '${BF_OPENAL}/include'
BF_OPENAL_LIB = 'openal'
BF_OPENAL_LIBPATH = '${BF_OPENAL}/lib'
WITH_BF_SDL = 'true'
BF_SDL = LIBDIR + '/sdl' #$(shell sdl-config --prefix)
BF_SDL_INC = '${BF_SDL}/include' #$(shell $(BF_SDL)/bin/sdl-config --cflags)
BF_SDL_LIB = 'SDL' #BF_SDL #$(shell $(BF_SDL)/bin/sdl-config --libs) -lSDL_mixer
BF_SDL_LIBPATH = '${BF_SDL}/lib'
WITH_BF_FMOD = 'false'
BF_FMOD = LIBDIR + '/fmod'
WITH_BF_OPENEXR = 'true'
BF_OPENEXR = '${LCGDIR}/openexr'
BF_OPENEXR_INC = '${BF_OPENEXR}/include ${BF_OPENEXR}/include/OpenEXR'
BF_OPENEXR_LIB = ' Iex Half IlmImf Imath IlmThread'
BF_OPENEXR_LIBPATH = '${BF_OPENEXR}/lib'
WITH_BF_DDS = 'true'
WITH_BF_JPEG = 'true'
BF_JPEG = LIBDIR + '/jpeg'
BF_JPEG_INC = '${BF_JPEG}/include'
BF_JPEG_LIB = 'jpeg'
BF_JPEG_LIBPATH = '${BF_JPEG}/lib'
WITH_BF_PNG = 'true'
BF_PNG = LIBDIR + '/png'
BF_PNG_INC = '${BF_PNG}/include'
BF_PNG_LIB = 'png'
BF_PNG_LIBPATH = '${BF_PNG}/lib'
BF_TIFF = LIBDIR + '/tiff'
BF_TIFF_INC = '${BF_TIFF}/include'
WITH_BF_ZLIB = 'true'
BF_ZLIB = '/usr'
BF_ZLIB_INC = '${BF_ZLIB}/include'
BF_ZLIB_LIB = 'z'
WITH_BF_INTERNATIONAL = 'true'
BF_GETTEXT = LIBDIR + '/gettext'
BF_GETTEXT_INC = '${BF_GETTEXT}/include'
BF_GETTEXT_LIB = 'intl'
BF_GETTEXT_LIBPATH = '${BF_GETTEXT}/lib'
WITH_BF_FTGL = 'true'
BF_FTGL = '#extern/bFTGL'
BF_FTGL_INC = '${BF_FTGL}/include'
BF_FTGL_LIB = 'extern_ftgl'
WITH_BF_GAMEENGINE='true'
WITH_BF_PLAYER='false'
WITH_BF_ODE = 'false'
BF_ODE = LIBDIR + '/ode'
BF_ODE_INC = '${BF_ODE}/include'
BF_ODE_LIB = '${BF_ODE}/lib/libode.a'
WITH_BF_BULLET = 'true'
BF_BULLET = '#extern/bullet2/src'
BF_BULLET_INC = '${BF_BULLET}'
BF_BULLET_LIB = 'extern_bullet'
BF_SOLID = '#extern/solid'
BF_SOLID_INC = '${BF_SOLID}'
BF_SOLID_LIB = 'extern_solid'
WITH_BF_YAFRAY = 'true'
#WITH_BF_NSPR = 'true'
#BF_NSPR = $(LIBDIR)/nspr
#BF_NSPR_INC = -I$(BF_NSPR)/include -I$(BF_NSPR)/include/nspr
#BF_NSPR_LIB =
# Uncomment the following line to use Mozilla inplace of netscape
#CPPFLAGS += -DMOZ_NOT_NET
# Location of MOZILLA/Netscape header files...
#BF_MOZILLA = $(LIBDIR)/mozilla
#BF_MOZILLA_INC = -I$(BF_MOZILLA)/include/mozilla/nspr -I$(BF_MOZILLA)/include/mozilla -I$(BF_MOZILLA)/include/mozilla/xpcom -I$(BF_MOZILLA)/include/mozilla/idl
#BF_MOZILLA_LIB =
# Will fall back to look in BF_MOZILLA_INC/nspr and BF_MOZILLA_LIB
# if this is not set.
# Be paranoid regarding library creation (do not update archives)
#BF_PARANOID = 'true'
# enable freetype2 support for text objects
BF_FREETYPE = LIBDIR + '/freetype'
BF_FREETYPE_INC = '${BF_FREETYPE}/include ${BF_FREETYPE}/include/freetype2'
BF_FREETYPE_LIB = 'freetype'
BF_FREETYPE_LIBPATH = '${BF_FREETYPE}/lib'
WITH_BF_QUICKTIME = 'true' # -DWITH_QUICKTIME
WITH_BF_ICONV = 'true'
BF_ICONV = LIBDIR + "/iconv"
BF_ICONV_INC = '${BF_ICONV}/include'
BF_ICONV_LIB = 'iconv'
BF_ICONV_LIBPATH = '${BF_ICONV}/lib'
# Mesa Libs should go here if your using them as well....
WITH_BF_STATICOPENGL = 'true'
BF_OPENGL_LIB = 'GL GLU'
BF_OPENGL_LIBPATH = '/System/Library/Frameworks/OpenGL.framework/Libraries'
BF_OPENGL_LINKFLAGS = '-framework OpenGL'
##CC = gcc
##CCC = g++
##ifeq ($CPU),alpha)
## CFLAGS += -pipe -fPIC -funsigned-char -fno-strict-aliasing -mieee
CFLAGS = ['-pipe','-fPIC','-funsigned-char','-fno-strict-aliasing']
CPPFLAGS = ['-fpascal-strings']
CCFLAGS = ['-pipe','-fPIC','-funsigned-char','-fno-strict-aliasing', '-fpascal-strings']
CXXFLAGS = ['-pipe','-fPIC','-funsigned-char','-fno-strict-aliasing', '-fpascal-strings']
PLATFORM_LINKFLAGS = '-fexceptions -framework CoreServices -framework Foundation -framework IOKit -framework AppKit -framework Carbon -framework AGL -framework AudioUnit -framework AudioToolbox -framework CoreAudio -framework QuickTime'
REL_CFLAGS = ['-O2']
REL_CCFLAGS = ['-O2']
##BF_DEPEND = 'true'
##AR = ar
##ARFLAGS = ruv
##ARFLAGSQUIET = ru
CC = 'gcc'
CXX = 'g++'
C_WARN = ' -Wall -Wno-long-double -Wdeclaration-after-statement '
CC_WARN = ' -Wall -Wno-long-double'
##FIX_STUBS_WARNINGS = -Wno-unused
LLIBS = 'stdc++ SystemStubs'
##LOPTS = --dynamic
##DYNLDFLAGS = -shared $(LDFLAGS)
BF_PROFILE_FLAGS = ' -pg -g '
BF_PROFILE = 'false'
BF_DEBUG = 'false'
BF_DEBUG_FLAGS = '-g'
BF_BUILDDIR='../trunkbuild/darwin'
BF_INSTALLDIR='../trunkinstall/darwin'
Greetz...Jens
P.S. If you have further problems, mail me.
