Bad IPO Auto Handle behavior
Kai Kostack
Post by Kai Kostack »
one example:
you can see the handles were set to vector now and all handles have a nice distance from its keys.
here i set them to auto but the resulting curves are anything else than smooth curves as i would expect when using auto handles.
i'm now forced to scale them manually up to get a smooth transition for example as a camera track.
why can't the horizontal distances between handles and keys not be kept like for vector handles?
here is the blend file: http://blendpolis.de/f/download.php?id=25365
i hope someone will improve the auto handle algorithm.
Kai Kostack
i had no time to wait, so i made some changes to curve.c myself and now the handles have always a constant 1/3 of the horizontal distance to the next key.
now the above example looks like this and i like it much better:
i replaced
Code: Select all
		len= 2.5614f*(float)sqrt(vx*vx + vy*vy + vz*vz);
with this
Code: Select all
		len= 6.0f;
i have to admit i don't know why there is this square root calculation in there but something must be wrong with it. maybe the original author should take a look into this.
