Blender under VS2008 - unresolved external symbol
Grumlaut
Post by Grumlaut »
After following the tutorial here for MSVC - http://www.geneome.net/index.php/tutori ... ing-cmake/ - I have been able to compile Blender fine, but I gt 22 link errors, any idea how I may fix these?
4>Linking...
5> Creating library D:\trunk\make\bin\Debug\blenderplayer.lib and object D:\trunk\make\bin\Debug\blenderplayer.exp
5>libjpeg.lib(jerror.o) : warning LNK4217: locally defined symbol __iob imported in function _output_message
5>libpng_st.lib(pngerror.o) : warning LNK4049: locally defined symbol __iob imported
5>libpng_st.lib(pngwutil.o) : warning LNK4049: locally defined symbol __iob imported
5>libpng_st.lib(pngrutil.o) : warning LNK4049: locally defined symbol __iob imported
5>IlmThread.lib(IlmThreadPool.obj) : error LNK2019: unresolved external symbol __invalid_parameter_noinfo referenced in function "char * __cdecl std::_Allocate<char>(unsigned int,char *)" (??$_Allocate@D@std@@YAPADIPAD@Z)
5>IlmImf.lib(ImfScanLineInputFile.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfPxr24Compressor.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfPizCompressor.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmThread.lib(IlmThreadSemaphoreWin32.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfMisc.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfTileOffsets.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfTiledMisc.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfTiledInputFile.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfStringAttribute.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfStdIO.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfChannelListAttribute.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfOpaqueAttribute.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfChannelList.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfTiledOutputFile.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfInputFile.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfAttribute.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>Half.lib(half.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfHeader.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfOutputFile.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>IlmImf.lib(ImfFrameBuffer.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
5>D:\trunk\make\bin\Debug\blenderplayer.exe : fatal error LNK1120: 1 unresolved externals
4> Creating library D:\trunk\make\bin\Debug\blender.lib and object D:\trunk\make\bin\Debug\blender.exp
4>libjpeg.lib(jerror.o) : warning LNK4217: locally defined symbol __iob imported in function _output_message
4>libpng_st.lib(pngerror.o) : warning LNK4049: locally defined symbol __iob imported
4>libpng_st.lib(pngwutil.o) : warning LNK4049: locally defined symbol __iob imported
4>libpng_st.lib(pngrutil.o) : warning LNK4049: locally defined symbol __iob imported
4>IlmThread.lib(IlmThreadPool.obj) : error LNK2019: unresolved external symbol __invalid_parameter_noinfo referenced in function "char * __cdecl std::_Allocate<char>(unsigned int,char *)" (??$_Allocate@D@std@@YAPADIPAD@Z)
4>IlmImf.lib(ImfScanLineInputFile.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfPxr24Compressor.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfPizCompressor.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmThread.lib(IlmThreadSemaphoreWin32.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfMisc.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfTileOffsets.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfTiledMisc.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfTiledInputFile.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfStringAttribute.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfStdIO.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfChannelListAttribute.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfOpaqueAttribute.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfChannelList.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfTiledOutputFile.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfInputFile.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfAttribute.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>Half.lib(half.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfHeader.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfOutputFile.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>IlmImf.lib(ImfFrameBuffer.obj) : error LNK2001: unresolved external symbol __invalid_parameter_noinfo
4>D:\trunk\make\bin\Debug\blender.exe : fatal error LNK1120: 1 unresolved externals
5>Build log was saved at "file://d:\trunk\make\blenderplayer\blenderplayer.dir\Debug\BuildLog.htm"
5>blenderplayer - 22 error(s), 4 warning(s)
4>Build log was saved at "file://d:\trunk\make\source\creator\blender.dir\Debug\BuildLog.htm"
4>blender - 22 error(s), 4 warning(s)
6>------ Skipped Build: Project: ALL_BUILD, Configuration: Debug Win32 ------
6>Project not selected to build for this solution configuration
========== Build: 3 succeeded, 2 failed, 56 up-to-date, 1 skipped ==========
malCanDo
Post by malCanDo »
Hi there,
I currently don't have the Blender source code checked out on my new laptop, but from what I recall you might want to check in the OpenEXR library folder.
This library contains the IlmBuf functionality, and there is more than one subfolder to choose from when linking ( there seems to have been an issue with how it was precompiled, which introduced incompatibilities with various versions of the VC compilers ).
You can see from above that this is the first error that you're getting, the previous ones were just warnings.
If you select the correct folder for the Blender project to link with for VS 2008, you should then ( hopefully ) be able to link.
Mal
jesterKing
Site Admin
Post by jesterKing »
I don't think CMake is currently too actively maintained. You might want to try scons/msvc to build blender.
/Nathan
tamerlan3d
Post by tamerlan3d »
I had the exact same issue building with Visual Studio 2005.
If you look the /lib/windows/openexr folder there are actually 4 different lib subfolders, lib, lib_msvc, lib_vs2005 and lib_vs2008.
To fix my issue I just changed my Additional Library Directories in the blender project to lib_vs2005.
I guess you'll have to do something similar to get it working.
qurui721
Post by qurui721 »
I have the same problem. :cry:
I have tried to link it with vc2008, and selected the directory:lib_vs2008....
EvilEngel
Same problem, any solution?
Post by EvilEngel »
I also have exactly the same problem. I'm using VC 2005 and my library directory is set to 2005 (I tried all of the other options just in case, but they're obviously worse). Was anyone able to work around this?
EvilEngel
fixed for me: python VS version
Post by EvilEngel »
My issue was resolved in a similar way as the posts above, but with a different library. I'm building with cmake and visual studion 2005 in debug mode. I had to tweak my cmakelists.txt to link against the python25_d library from the lib25_vs2005 sub folder. Also tweaked the post build command for the blender project to copy the right dll. This thing of having to match all of these different versions of libraries with the MS compilers is painful, painful.
jesterKing
Site Admin
The best out-of-the-box experience you can get by building blender with the combo scons+msvc (It's how official builds are done).
/Nathan
ab2cd4
Post by ab2cd4 »
The problem here is that openexr is compiled for release.
To make a debug build of Blender with Microsoft VC you'd need to compile the openexr libraries in debug mode.
Here you are mixing release and debug, which won't work with the libraries which are included for windows. They are build as multi-threaded (/MT), but to build a debug version it has to be multi-threaded debug (/MTd).
jesterKing
Site Admin
You should not need to debug the openexr libraries, they are supposed to be black box dependencies. Also, our build process (at least when using scons+msvc) doesn't need the openexr debug libraries to build a debug version of Blender.
/Nathan
berttreb
Post by berttreb »
I had a similar problem when building 2.48 debug in Visual C++ Express edition 2008. I used cmake to create the project files.
Everything compiled correctly but during linking this error appeared a number of times:
In openexr_api.cpp I found this code (near the top of the file, line 39)
// The following prevents a linking error in debug mode for MSVC using the libs in CVS
#if defined(WITH_OPENEXR) && defined(_WIN32) && defined(_DEBUG) && !defined(__MINGW32__) && !defined(__CYGWIN__)
_CRTIMP void __cdecl _invalid_parameter_noinfo(void)
#endif
So I think in my case one or other define constant (eg. _DEBUG) was not set (by cmake ?).
Solution: I commented the #if defined ... and #endif so that the function _invalid_parameter_noinfo is defined.
Now the compilation works and I can step through the code with the debugger in visual express.
Regards
PS. I presume when compiling release the comments will need to be removed.
jesterKing
Site Admin
berttreb wrote:Solution: I commented the #if defined ... and #endif so that the function _invalid_parameter_noinfo is defined.
Regards
Of course, a better solution even would be to make sure that the _DEBUG define is created for debug builds.
/Nathan
Fussion289
Post by Fussion289 »
berttreb wrote:Hi,
#endif
Regards
Any way of getting a copy paste of exactly what you did to make it more apprent to use noobs?
:lol:
What mean you my engrish no well???
mankatob
changing my Additional Library Directories
Post by mankatob »
Okay, I've bought Visual Studio 2005 and 2003 and I've got others but I've added Scons and I suppose I should download whatever microsoft is giving away for free if only because I want to be just like you;} And I've run the scripts and played the games.
Product:
*,class std::basic_string<char,struct std::char_traits<char>,class std::allocat
IlmImf.lib(ImfStdIO.obj) : error LNK2001: unresolved external symbol "public: s
std::basic_string<char,struct std::char_traits<char>,class std::allocator<char>
HOW DO I SPECIFY THE COMPILER I AM USING? THERE IS NO config.opts, no user-config.py
"If you look the /lib/windows/openexr folder there are actually 4 different lib subfolders, lib, lib_msvc, lib_vs2005 and lib_vs2008.
To fix my issue I just changed my Additional Library Directories in the blender project to lib_vs2005. " <<_-----HOW DID HE?SHE DO THAT?
win32-vc-config.py mentions nothing as does the Sconstruct script.
