svn code, cmake,vc2008sp1, blender.exe(Debug), UI errors
yaoyansi
Post by yaoyansi »
Hi all,
My enviroment is: WinXP/x32,cmake2.8,vc2008sp1,python26(added to %PATH%)
I check out the latest svn code, and use cmake to generate vc2008 build scripts, then I choose Debug version in vc2008sp1 and build the blender project. When Debug\blender.exe is generated , I copy it to BLENDER_TRUNK\install\win32-vc\blender.exe and launch it. It complains
python32_d.dll is not exist. So I copy BLENDER_TRUNK\lib\windows\python\lib\python32_d.dll to BLENDER_TRUNK\install\win32-vc\python32_d.dll and launch blender.exe again.
But this time it complains the following errors,
Code: Select all
found bundled python: E:\dev\blender\svn\trunk\install\WIN32-~2\2.56\python
  File "E:\dev\blender\svn\trunk\install\WIN32-~2\2.56\scripts\modules\bpy\__ini
t__.py", line 23, in <module>
    from _bpy import types, props, app
ImportError: cannot import name app
search for unknown operator WM_OT_context_set_enum, WM_OT_context_set_enum
RNA_string_set: OperatorProperties.data_path not found.
RNA_string_set: OperatorProperties.value not found.
search for unknown operator RENDER_OT_play_rendered_anim, RENDER_OT_play_rendere
d_anim
search for unknown operator WM_OT_context_cycle_enum, WM_OT_context_cycle_enum
search for unknown operator WM_OT_context_toggle, WM_OT_context_toggle
search for unknown operator OBJECT_OT_select_hierarchy, OBJECT_OT_select_hierarc
hy
RNA_enum_set_identifier: OperatorProperties.direction not found.
hy
RNA_boolean_set: OperatorProperties.extend not found.
hy
hy
search for unknown operator OBJECT_OT_subdivision_set, OBJECT_OT_subdivision_set
RNA_int_set: OperatorProperties.level not found.
search for unknown operator WM_OT_context_toggle_enum, WM_OT_context_toggle_enum
RNA_string_set: OperatorProperties.value_1 not found.
RNA_string_set: OperatorProperties.value_2 not found.
search for unknown operator VIEW3D_OT_edit_mesh_extrude_move_normal, VIEW3D_OT_e
RNA_boolean_set: OperatorProperties.relative not found.
search for unknown operator BRUSH_OT_set_active_number, BRUSH_OT_set_active_numb
er
RNA_string_set: OperatorProperties.mode not found.
RNA_int_set: OperatorProperties.number not found.
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
search for unknown operator WM_OT_context_menu_enum, WM_OT_context_menu_enum
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
er
search for unknown operator WM_OT_context_cycle_int, WM_OT_context_cycle_int
RNA_boolean_set: OperatorProperties.reverse not found.
search for unknown operator SEQUENCER_OT_cut_multicam, SEQUENCER_OT_cut_multicam
RNA_enum_set: OperatorProperties.camera not found.
search for unknown operator WM_OT_context_set_int, WM_OT_context_set_int
RNA_int_set: OperatorProperties.value not found.
search for unknown operator CONSOLE_OT_execute, CONSOLE_OT_execute
search for unknown operator CONSOLE_OT_autocomplete, CONSOLE_OT_autocomplete
search for unknown operator WM_OT_url_open, WM_OT_url_open
RNA_string_set: OperatorProperties.url not found.
and the UI can't be displayed correctly.
Then I read this page(http://wiki.blender.org/index.php/Dev:2 ... er/Windows), and use this command
>python scons\scons.py
to generate BLENDER_TRUNK\install\win32-vc\blender.exe;
Then launch BLENDER_TRUNK\install\win32-vc\blender.exe, every thing is OK.
So, what's wrong when I build blender.exe with VC2008?
Thank you.
skurdakov
Re: svn code, cmake,vc2008sp1, blender.exe(Debug), UI errors
Post by skurdakov »
if you track dev mailing list bf-commiters then you might notice recent transition to python 3.2 - quite bumpy for some devs, and which is source of your bug.
the transition is really fresh - so even with python 3.2 the errors are expected not to mention python 2.6
either you drop for now python 2.6 or get earlier code ( few days back ) or wait till things will settle.
skurdakov
Post by skurdakov »
one tip though - you should run INSTALL project in VisualStudio to copy all necessary files.
I did just that on the fresh copy of svn and all goes well
kestion
Post by kestion »
I'm having the same problem.
I gave up on building an x64 version for now as it seemed to be a shelf full of cans full of worms. I removed python32 from the system path and added python27 in the vc2008Express command prompt.
I built with cmake -now targeting vc 9.0 2008 win32. Now it compiles happily, but I get the same error on startup about missing python32_d.dll. I moved that over to the blender.exe folder and now i get complaints of not finding gnu_Gettext.dll .
It seems this could be fixed by adding c:\BlenderSVN\blender\lib with all its subdirectories to the path, but I don't know of a way to add all subdirectories. (for PATH, what you see is what you get right?)
My fetch from the trunk was about a week ago. How far back before we get to a stable build env?
will try the scons again now.
thanks!
kesten
stiv
Post by stiv »
I *believe* there is an 'install' target for cmake that puts files into the install dir. (have not paid close attention since happily sconzing myself)
Generally speaking, the build environments *are* stable. You are having problems with your local setup. Currently, the development branches from Google Summer of Code are being merged to trunk for the next release. This can break builds, but usually only lasts for a day or so.
The #blendercoders IRC channel on freenode.net can be a good place to get help with build problems.
kestion
scons and cmake compile problems
Post by kestion »
stiv wrote:I *believe* there is an 'install' target for cmake that puts files into the install dir. (have not paid close attention since happily sconzing myself)
I re-fetched the lead release from the blender trunk today. Then i tried compiling with cmake and scons.
Cmake still gets stuck on gnu_gettext.dll . I guess a library path is missing somewhere.
Scons. I noticed that scons puts the build in C:\BlenderSVN\install\blender25-win64-vc
I don't recall telling scons at any point that i wanted an x64 build. I presume the win64-vc means it is trying to build 64 bit code - which i have given up on. I found all the config files in
c:\BlenderSVN\build_files\scons\config\
and it looks like i should be using win32-vc-config.py instead of win64"~" but I don't know how scons is picking the x64 config file instead of the win32 config file. I searched for 64-vc under the BlenderSVN folder but got nothing so scons must be detecting or generating it somehow.
stiv wrote:The #blendercoders IRC channel on freenode.net can be a good place to get help with build problems.
will try there next.
yaoyansi, since we seem to be having the same problem, did you want to team up on troubleshooting this? email solarmobiletrailers@gmail.com . (personal messaging is disabled for this forum).
kesten
stiv
Post by stiv »
Scons runs Python and looks at the value of sys.platform in order to figure out were it is. You can tell it to use a particular config file (sorry, not in front of my development environment at the moment)
