I am trying to compile 64 bit blender 2.9 on a windows 7 machine.
I tried cmake first but got errors, so I'm now working with scons.
I had python2.7 on my machine. Scons compiled everything happily
but while linking makesdna.exe i got the error:
module machine type 'X86' conflicts with target machine type 'x64'
I tried seval things with no luck so I installed python3.2 since i noticed blender was built with this version.
Now when i run scons it can't get out of the starting gate. I get an error that comes from the scons.py file i'm guessing. The error states that environ has no such attribute has_key
[offending lines from scons.py]
if os.environ.has_key("SCONS_LIB_DIR"):
libs.append(os.environ["SCONS_LIB_DIR"])
From what i've read, has_key was used in python2 but dropped in python3.
So it appears that blender can't be scons-built with python3 even though it is internally built with python3.2? REALLY? I used tortoiseSVN to grab the trunk from blender just last week.
I guess I'll go back to python2.7 and try to find the error with the linker between module machine and target machine.
Been at this a few days now. Any help appreciated.
scons.py errors with python 3.2
This
I agree.
>python gives the version as 64 (amd) on win32. I always download the x64 if it is available. But what does 64 on win32 mean?
2 problems:
1. If i use python3.2 i can't run scons.py because i get an error since has_key no longer exists in python3. Has anyone compiled blender using scons and python3? Do tell!
2. If i use python2.7 then all compiles well, but i get the linker error. I downloaded the \lib\64 binaries as suggested on the blender.org compiling tutorial. But i haven't figured out which compiler scons uses or if it is linking to the lib\64 binaries.
However, I found that even trying to compile a simple helloWorld.cpp using the Visual Studio 2010\VC\bin\amd64\cl.exe at command prompt, it compiles fine but gives the same linking error. What is being linked? <iostream> and a system("PAUSE") call are the only pieces of code in there.
Building with config mgr set to x64 does work from within vs 2010 IDE on the helloworld.cpp.
Do i need to pass some options to the cl.exe compiler to get the command line linker to work? How can i find out what VS 2010 is doing to make the linking work?
thanks,
kesten
sounds like some mix 32 bit and 64 bit prorams. Are you running 32 bit Python?[/quote]module machine type 'X86' conflicts with target machine type 'x64'
I agree.
2 problems:
thanks,
kesten
Let's try again:
Blender needs to find Python 3.2 libraries and header files in order to build. It does not care about a Py 3.2 executable.
To run SCons, you need a Python 2.x executable. SCons does not work with Python 3 yet.
It has been a while since I was afflicted with Visual Studio, but the fact that you cannot link Hello World suggests something is wrong with your setup. Are you perhaps running a 32 bit version of Windows on a 64 bit processor?
I have windows7 64bit on a 64 bit processor.
Cl.exe does compile hello world correctly if I configure vs2010 to build target x64.
I have both python32 and python27 installed at c:\. Currently I only have python27 in the path, but i think scons should find python32 as well.
My main concern now is that scons somewhere chooses to use win64-vc-config.py rather than win32-vc-config.py from directory C:\BlenderSVN\blender\build_files\scons\config
And creates the build directory C:\BlenderSVN\build\blender25-win64-vc
It is not clear from the naming or documentation weather the win64 is refering to the build machine (correct for me) or the target executable (win32 in my case). I think its the executable in which case, scons is incorrectly guessing that i want an x64 build. ( i did, until i ran into too many troubles and opted for win32)
Any tips as to where to find the scons script that decides which config to use?
thanks
kesten
thanks
kesten
