Compiling with msvc6: Link error
wglwill
Post by wglwill » Sat Sep 20, 2003 7:55 pm
I'm getting a linker error when compiling blender 2.28a with visual c++ 6. I also get a number of linker warnings. I'm not sure if they are related to the linker error but I pasted them below anyways. The actual link error occurs on the last half dozen lines of this linker output.
--------------------Configuration: blender - Win32 Release--------------------
Linking...
   Creating library ..\..\bin\blender.lib and object ..\..\bin\blender.exp
LINK : warning LNK4049: locally defined symbol ""public: bool __thiscall FTFont::CharMap(enum FT_Encoding_)" (?CharMap@FTFont@@QAE_NW4FT_Encoding_@@@Z)" imported
LINK : warning LNK4049: locally defined symbol ""public: bool __thiscall FTFont::FaceSize(unsigned int,unsigned int)" (?FaceSize@FTFont@@QAE_NII@Z)" imported
LINK : warning LNK4049: locally defined symbol ""public: __thiscall FTGLPixmapFont::FTGLPixmapFont(char const *)" (??0FTGLPixmapFont@@QAE@PBD@Z)" imported
LINK : warning LNK4049: locally defined symbol ""public: virtual __thiscall FTGLPixmapFont::~FTGLPixmapFont(void)" (??1FTGLPixmapFont@@UAE@XZ)" imported
LINK : warning LNK4049: locally defined symbol ""public: float __thiscall FTFont::Ascender(void)const " (?Ascender@FTFont@@QBEMXZ)" imported
LINK : warning LNK4049: locally defined symbol ""public: float __thiscall FTFont::Descender(void)const " (?Descender@FTFont@@QBEMXZ)" imported
LINK : warning LNK4049: locally defined symbol ""public: float __thiscall FTFont::Advance(unsigned short const *)" (?Advance@FTFont@@QAEMPBG@Z)" imported
LINK : warning LNK4049: locally defined symbol ""public: void __thiscall FTFont::BBox(unsigned short const *,float &,float &,float &,float &,float &,float &)" (?BBox@FTFont@@QAEXPBGAAM11111@Z)" imported
LINK : warning LNK4049: locally defined symbol "__iob" imported
FTF_ftfont.lib(FTF_TTFont.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: int __thiscall FTFont::Error(void)const " (__imp_?Error@FTFont@@QBEHXZ)
..\..\bin\blender.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
blender.exe - 2 error(s), 9 warning(s)
Does anyone know what might be causing this?
alien-xmp
Post by alien-xmp » Sun Sep 21, 2003 5:12 am
Install FTGL?
http://homepages.paradise.net.nz/henryj/code/
FTGL is a library for drawing TrueType fonts in OpenGL.
ascotan
Post by ascotan » Sun Sep 21, 2003 6:04 pm
You may have to checkout the lib/windows checkout from the CVS and link the windows specific libs to blender. In the .dsp files there are some lines for libpath/"blah..." that give paths to the libraries to link to the module.
theeth
Post by theeth » Sun Sep 21, 2003 11:00 pm
If you checkout the lib folder from CVS in the same folder where you put the blender folder, you shouldn't have to edit the linking path in the MSVC project files.
- John Lennon
gabio
Post by gabio » Thu Jan 15, 2004 5:56 pm
i got this error with scons, i have the last checkout so i don't understand the problem here. I have downloaded FTGL but the libs is already in the lib module so... any real hint how to fix this?
guitargeek
Post by guitargeek » Mon Feb 23, 2004 7:09 pm
yes, I am having the same trouble with scons. it builds fine within MSVC, but not with scons.
