libGL.SO problem compiling blender with cmake
npm1
Post by npm1 »
Scanning dependencies of target blender
[100%] make[3]: *** No rule to make target `/usr/lib/x86_64-linux-gnu/libGL.so', needed by `bin/blender'. Stop.
make[3]: *** Waiting for unfinished jobs....
Building C object source/creator/CMakeFiles/blender.dir/buildinfo.c.o
make[2]: *** [source/creator/CMakeFiles/blender.dir/all] Error 2
make[1]: *** [all] Error 2
make: *** [all] Error 2
AMD HD Radeon 6950 2GB,AMD phenom x6 1055t,
latest proprietory driver from amd 11.12....
how i resolve this issue, i followed compilation from the wiki and automatic cmakei .e.
My pc rig windows7 thinking of dual boot, 500gb, 500gb, 650gb, 2tb hdds, 16gb ram, 6950 2gb, amd phenom x6.......looking forward to amd hd 7000 gpus .... and cycles opencl
SLG should help(Opencl AMD) cycles and cycles should help(Optimization) SLG
stiv
Post by stiv »
The libGL.so is OpenGL. Either you do not have it installed, or the path to the library is set incorrectly and does not match your system.
ldo
Post by ldo »
On my Debian system:
Code: Select all
ldo@theon:~> dpkg-query -S /usr/lib/x86_64-linux-gnu/libGL.so
libgl1-mesa-dev: /usr/lib/x86_64-linux-gnu/libGL.so
So assuming you’re on a Debian derivative (e.g. Ubuntu), you’ll need to install the package “libgl1-mesa-dev”.
npm1
Post by npm1 »
ldo wrote:On my Debian system:
Code: Select all
i appreciate the very quick response. thank u........
but doesnt catalyst 11.12, installs the needed file
npm1
Post by npm1 »
Code: Select all
according to synaptic that dependancy/package is already installed.........
found this
[/url]http://forums.linuxmint.com/viewtopic.p ... 383689[url] following the instructions my terminal produces this.......
Code: Select all
sudo ldconfig -v|grep GL
/sbin/ldconfig.real: Can't stat /lib32: No such file or directory
/sbin/ldconfig.real: Can't stat /lib/i686-linux-gnu: No such file or directory
/sbin/ldconfig.real: Can't stat /usr/lib/i686-linux-gnu: No such file or directory
/sbin/ldconfig.real: Path `/lib/x86_64-linux-gnu' given more than once
/sbin/ldconfig.real: Path `/usr/lib/x86_64-linux-gnu' given more than once
	libGL.so.1 -> libGL.so.1.2
/sbin/ldconfig.real: Cannot stat /usr/lib/x86_64-linux-gnu/libjackserver.so: No such file or directory
/sbin/ldconfig.real: Cannot stat /usr/lib/x86_64-linux-gnu/libGL.so: No such file or directory
	libGLU.so.1 -> libGLU.so.1.3.071100
	libQtOpenGL.so.4 -> libQtOpenGL.so.4.7.4
/sbin/ldconfig.real: Cannot stat /usr/lib/x86_64-linux-gnu/mesa/libGL.so: No such file or directory
	libGLEWmx.so.1.5 -> libGLEWmx.so.1.5.2
	libGLEW.so.1.5 -> libGLEW.so.1.5.2
t#my installation of ubuntu 11.10 is upgraded from a fresh install of ubuntu 11.04.......[/quote][/url]
stiv
Post by stiv »
Another way to look at this is to ask:
Do you have a libGL.so file somewhere? (as a symlink pointing to the actual library.)
Is the path to libGL.so correct in your build system config file?
npm1
Post by npm1 »
stiv wrote:Another way to look at this is to ask:
thanxs again
where is the orginal libGL.so(where do you find your one)
where should it be
from there i could put a symlink in the required folder........ i.e. my build system is looking at
/usr/lib/x86_64-linux-gnu/libGL.so.....this point....
do i put a symlink in that folder....
stiv
Post by stiv »
Do NOT do this, for a bunch of reasons.
1) Make sure you have opengl installed. do
locate libGL.so
or more slowly
find / -name libGL.so
You should see something like (for example)
/usr/lib/libGL.so
/usr/lib/libGL.so.1
/usr/lib/libGL.so.290.10
The first two items are symlinks pointing to the next file in that list. Here, the libGL.so.290.10 is the actual library
2) Make sure you build config file matches what you found in step 1.
If you do not have OpenGL, you need to install it.
bhattigurjot
Re: libGL.SO problem compiling blender with cmake
Post by bhattigurjot »
npm1 wrote:Scanning dependencies of target blender
Solve this using:
sudo ln -s -f -i /usr/lib/libGL.so.1.2 /usr/lib/x86_64-linux-gnu/libGL.so
