How to recompile to support AMD OpenCL on Mac?
Acrossfy
Post by Acrossfy »
Hi, i have a AMD HD7950 GPU and I want use Cycles Render in OpenCL mode on my OS X system.
oclinfo shows following log:
Code: Select all
[Device 2]
	Name: 			ATI Radeon HD 7950 Compute Engine
	Vendor: 		AMD
	Type: 			GPU
	Device Version: 	OpenCL 1.1
	Driver Version: 	1.0
	Compute Units: 		32
	Work Group Size: 	1024
	Clock: 			1000 MHz
	Global Memory: 		1536 MB
	Local Memory: 		32 KB
	Cache Size: 		0 KB
	Cache Line Size: 	0 Bytes
	Available: 		Yes
	Double-Precision: 	No
	Extensions:
				cl_APPLE_SetMemObjectDestructor
				cl_APPLE_ContextLoggingFunctions
				cl_APPLE_clut
				cl_APPLE_query_kernel_names
				cl_APPLE_gl_sharing
				cl_khr_gl_event
				cl_khr_global_int32_base_atomics
				cl_khr_global_int32_extended_atomics
				cl_khr_local_int32_base_atomics
				cl_khr_local_int32_extended_atomics
But Blender can use only CPU mode. I heard i need to recompile Blender with edited kernel_types.h and device_opencl.cpp files. Are there any additional tips? What exactly i must edit?
Thanks in advance.
P.S. I'm programmer (but on Java)
