Dynamic Topology Problem.
humanpenguin
Post by humanpenguin »
Hi. Please point me to the right forum if this is not the correct place to ask this.
I have been trying to play with Sculpting using dynamic topology. The issue I am having is every time I switch the Dynamic toggle on. The display of the opbect goes extreamly screwy.
This can be anying from no object at all to the edges sticking out is all sorts of strange directions. Most extending well beyond the view port.
This seems to be an issue with my own modles and with the default cube in new.
It seems to be purly a display issue. As when I experioment and switch back to non dynamic mode the changes are applied.
It also works in render view. Just not any other mode.
I am currently using version 2.68a r59654
but have seen this on every revision I have tried to compile in the last couple of weeks.
If anyone could tell me what I am doing wrong. Or let me know how and what other info to provide to help diagnose the problem. Id be very thankfull.
