Cygwin compiling with Python
harkyman
Post by harkyman »
I've tried compiling a number of times at work with zero success.
I'm trying on my home box, this time, Win2K Pro, using free tools. I've read all the docs available here, but they don't seem to address my level of noobishness in this.
First question: cygwin setup allows me to install a Python package, but it looks like it will only allow me to use 2.3.3 or 2.3.1. What am I going to need to do to install Python 2.2 (which is what Blender uses, right?), and do I need to have cygwin download source as well as binaries?
Hos
Post by Hos »
You don't need the cygwin python installed to build
blender(in fact, you don't need *any* pythin installed)
... the python stuff you need will be obtained from the
lib/windows module that you get in step 4 of the doc:
http://projects.blender.org/viewcvs/vie ... text/plain
Chris
lightning
Post by lightning »
Ok, you can try my way, or go to blender/doc/README.windows-gcc in the cvs (its a text file) and that's the official instructions.
I assume that you already have the cvs code? You have to make sure that you have the directory set up right, I havent built it for a while but from what I remember it should look a bit like this:
ROOT\blender checkout\(source, external, internal etc.)
\lib checkout\(windows\python, png etc.)
Then you have to have about every cygwin library under the sun, so I hope you have broadband or faster!
After that, you go into root\blender checkout, type
Code: Select all
EXPORT FREE_WINDOWS=true
(You better check that, it should be in the docs section of the cvs; root\blender checkout\doc)
and then type make. hopefully it works.
If not, give us the output where it crashes and that will make it easier to find your problem.
btw if i've said somthing thats out of date or just plain wrong, someone point it out and I'll change it ;)
The dawn of a new error...
harkyman
Post by harkyman »
Thanks guys. My failures have been using the provided linked instructions. I'm trying on a different machine this time. I keep my home box lean and mean, so I'm hoping things will work out better on it.
harkyman
Post by harkyman »
First snag, and it seems to be the same one I've encountered on my work machines. After dlltool creates a pile of stub files, I get this:
Code: Select all
dlltool: Creating stub file: dsvs00750.o
dlltool: Creating stub file: dsvs00751.o
dlltool: Created lib file
ranlib /home/Administrator/bf-blender/blender/../lib/windows/python/lib/freepy.a
rm ./python22.dll
====> make all in blender/intern
====> make all in intern/string
====> make all in intern/string/intern
g++ -c -pipe -mno-cygwin -mwindows -DNDEBUG -O2 -Wall -W -Wshadow -Wpointer-arit
h -Wbad-function-cast -Wcast-qual -Wcast-align -Wstrict-prototypes -Wmissing-pro
totypes -Wmissing-declarations -Wnested-externs -Wredundant-decls  -Wreorder -Wc
tor-dtor-privacy -Wnon-virtual-dtor -Wold-style-cast -Woverloaded-virtual -Wsign
-promo -Wsynth  -DFREE_WINDOWS -I.. STR_String.cpp -o /home/Administrator/bf-ble
nder/blender/obj/windows/intern/string/STR_String.o
make[3]: g++: Command not found
make[3]: *** [/home/Administrator/bf-blender/blender/obj/windows/intern/string/S
TR_String.o] Error 127
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make: *** [all] Error 1
Any help? Also, anyone want to give me some theory on what I'm seeing here so I can try to troubleshoot things like this myself?
lightning
Post by lightning »
It looks like you need some more of the cygwin binarys. Have you tried the link that Hos posted? It has a list of the binarys that you need to install. I think the one your looking for is gcc and possibly gcc-mingw as well.
Good luck!
harkyman
Post by harkyman »
I've followed the instructions. I told cygwin to get the gcc and gcc-mingw binaries, but I'll double check tonight. Thanks.
harkyman
Post by harkyman »
Woo freaking hoo! Compiled and running. I rechecked the cygwin packages. gcc (which is what the docs call for) and g++ are listed seperately in the cygwin installer. When I told it to get me g++, everything worked beautifully.
The docs should be changed to reflect this newbie stumbling block.
