where_is_object function / particles and armatures
leon
Post by leon »
hi all,
while working on the particle deflection stuff, one of the things I came across was that the "where_is_object" function (from object.c) doesn't seem to report the location correctly in ob->obmat if an emitter is parented to an armature (at least, if I call the function from effect.c).
I assume this is the reason you can't parent emitters to armatures.
Can any guru coders tell me if there are any "special requirements" for using the where_is_object function? i.e. any variables I should be setting etc....
Cheers
Leon
Hos
Post by Hos »
Maybe try this on the armature parent before doing the where_is_object():
clear_pose_constraint_status(ObArm);
make_displists_by_armature (ObArm);
Chris
