Blender on Fedora Core 2
Just came across the blender app a couple days ago and was wondering if anyone has built it from source on FC2 yet and, if so, what were the snags.
Thx
Huw
Thx
Huw
FC2 final - building problem or just me being newb?
i downloaded the blender-2.33a.tar.gz source file.
extracted it to /home/enablerbr3/
opened up a terminal as user. "cd" into /home/enablerbr3/blender-2.33a/
typed scons and let it do it's thing.
when it finished i ended up with a /home/enablerbr3/build/linux2/ folder with the following folders extern, intern, lin, source. and the following files makesdna, scons-signatures.
yet there was no blender file. when i looked in /home/enablerbr3/blender-2.33a/ the blender execute file was in there.
i'm a newbie to using scons and followed the INSTALL instructions. so did i do something wrong or is that how it was supposed to turn out. i'm also a newbie to linux aswell.
oh the blender execute did work but not all the inport/export plugins showed up. so do i still need to do something else with the /home/enablerbr3/build/linux/ folder or the /home/enablerbr3/blender-2.33a/ folder?
ok heres how I do it on Fedora Core 2
1. on the left you will see CVS
2. make a directory called blender and follow the instructions to download the latest cvs
( you do this from a shell, when you are root)
put in the first line, press enter, when it asks you for a password press enter again
put in the second line and change "modulename" to blender (watch your spelling
3. now I assume you have scons installed
4. navigate to /code /blender
5. type in scons and hit enter
6. after awhile, you will have a fresh new blender exec in /code/blender
hope that helps
hope that helps
- Site Admin
Re: FC2 final - building problem or just me being newb?
This is exactly what you should expect. Consider yourself passed for the SCons examenablerbr wrote:i downloaded the blender-2.33a.tar.gz source file.
You have to copy the blender binary into the /home/enablerbr3/blender-2.33a/bin/ directory. This dir contains all you need.
/jesterKing
hey im also running off FC2 but im having some problems. Im new to Linux and so far this and Wine are the only Apps I can't install. I unzipped Blender-2.33a.tar.gz to /home/devon/ and typed in the terminal as root cd blender-2.33a/. I then typed scons like enablebr did before but it said bash: scons: command not found. So I went to the directory and found SConstruct and typed it in the command console and it said Permission denied I tried it as devon (not root) and it said the same thing. Am i doing this wrong? I am used to just typing
Code: Select all
./configure
make
make install
Likely this is becausebut it said bash: scons: command not found.
1) You installed scons into the default /usr/local dir.
2) you are running as root who typically does not have /usr/local/bin in PATH.
You do not need to be root to build blender, only to install stuff into system directories.
You did install scons, yes?
Oh you have to install a seperate package....i didn't know that....where can i get this 'scons'?stiv wrote:Likely this is becausebut it said bash: scons: command not found.
- Site Admin
autoconf et al. has been discontinued since the fourth of January, 2004.Phreakster001 wrote:I am used to just typingCode: Select all
./configure make make install
/jesterKing
