build failure with cygwin, gcc
Marty_D
Post by Marty_D »
[edit]
iluvblender
Post by iluvblender »
i had the same problem too.
cl.exe should be in \\Microsoft Visual Studio\VC98\Bin
i just put the full path in the environment variable PATH. also had to put this in the path: \\Microsoft Visual Studio\Common\MSDev98\Bin
remember put the full path.
in my case it was.
C:\Program Files\Microsoft Visual Studio\Common\MSDev98\Bin
and
C:\Program Files\Microsoft Visual Studio\VC98\Bin
hope it helps.
bjornmose
Post by bjornmose »
if you want to build with gcc
you must "export FREE_WINDOWS=true"
in the user-def.mk like stated in the guides above.
if you want to build with MSVC, iluvblender is right.
BM
Marty_D
Post by Marty_D »
[edit]
