THE N-GONS PROJECT
Youssef|3d
Post by Youssef|3d »
hi guys
I just want to explain why so much people want ngons, but befor I start keep something in your mind: "ngons won't make you a better artist" maybe a faster one
the reason why many people like ngons is the concept that is behind ngons modeling. you start with a primitive and model the rough form of the object out, it's a bit like drawing. if you want to draw a head or a body you start with a box or a ball or something like that as well.
later you can add the details. in this process you will get ngons but never mind, you can retopologize how you want and there is no algo that change a face to a triangle.
after intigrating the ngons meshsystem we will have more poly tools that you know from other 3dpacks that allow ngons
so do we realy need that ? if you are a poly by poly modeller you will say no because you don't need that and don't feel comfortable with that but for us (the guys who like boxmodeling) we will say yes because it offers us so much and we can control the vertices number of the poly.
here are more informations:
http://www.subdivisionmodeling.com/wiki ... x+Modeling
something that I noticed are sentences like : "blender doesn't need that because I see no need for that" keep always in mind that there are a lot of guys who see more need in this or that because they know how to use it and understand it.
about the ngons project: well I think the intigration of ngongs in blender is hard and needs time.
there are other projects which have too much priority
all in all I think that it is a question of time until we will get ngons in blender but in this time you can use wings like I do.
see ya :wink:
artisanicview
Post by artisanicview »
Well, I think this afirmation is stated by someone who never worked with NGONS. Please take a look here:
http://blenderartists.org/forum/showthr ... hlight=2.4
And count how manny are asking for NGONS in Blender.
One of the most asket feature for post 2.32 is NGONS. Why? Beacouse they are werry useful. All serious applications have this. You can pointme a PRO app who dont haveit? Surely not! Why a lot of users are using Wing? Beacouse have NGONS!
Azrael
Post by Azrael »
Choice is better than no choice. NGons would open a whole new toolbox. We are talking about MORE tools, not less. More choice is better, yes? You don't like NGons and you model poly by poly? Great, just keep doing what you are used to. You want to Box Model and use NGons? Great, just keep doing what you are used to. Or hey, you like poly poly modeling AND you use NGons in your workflow. Great, just keep doing what you are used to.
I think that just the fact that so many of us disagree shows that people want choice.
Let's 'face' it, you can model how you're used to, either way.
joeri
Post by joeri »
I think people want ngons because it makes subdivsurf life easier.
It also opens up easier tools for beveling.
But as I understand it it's not easy to implement in blender because of the current data system. ie. the way a vertex-edge-face is handled in memory.
Changing this reaches right in the hart of blender, the vertex system. All other areas need to adjust to that: modeltools, materials, textures, mapping, rendering. Everything. So,... who of the "demanders" wants to lead that project?
Azrael
Post by Azrael »
The person who will lead this will surface if it's something the community wants. I vote for it, I'm part of the community, I hope more people vote for it.
moh taia
Post by moh taia »
I vote for it too
N-gons will give blender almost unlimited modelling options
LetterRip
Post by LetterRip »
it isn't a 'voting' based thing :)
It is more dependent on the developers free time. Briggs is working on a new ngons implementation and the basic functionality is there - it might make it for 2.5 but also might not.
LetterRip
kitsu
Post by kitsu »
Good news LetterRip! does he have a wiki page up yet?
LetterRip
Post by LetterRip »
He might but i don't think so,
LetterRip
Timothy
Post by Timothy »
kitsu
Post by kitsu »
Wow, very good proposal! The constraints you've set are very sane, and it looks like you have lots of clever ideas on data formatting. I look forward to testing builds ;)
Timothy
Post by Timothy »
kitsu wrote:Wow, very good proposal! The constraints you've set are very sane, and it looks like you have lots of clever ideas on data formatting. I look forward to testing builds ;)
That isn't my work,.. Briggs is working on that.
Azrael
NGONS
Post by Azrael »
That is looking very promising. I look forward to trying it out. :-)
Thank you Briggs!
FreakyDude
Post by FreakyDude »
artisanicview wrote:"blender doesn't need that because I see no need for that"
I've worked with Ngons, I don't think I need them. I wouldn't mind them being there, but I have one concern about em:
When I got used to just tris and quads it appearred a hell of a lot easier to see what is going on in your mesh. It's easier to keep clean, box modeling or poly by poly. It's easier when you cut. Sure you may have to clean up some new verts afterwards, but that often also goes for Ngon modeling.
I don't like carefully cutting my mesh up finding it has some weird huge ngons afterwards that disrupt flow, or verts moved very closely to each other and you get weird shading artifacts or somthing. it''s a pain when you've aligned your original verts and can't really determine which ones were original and which were newly created.
If there where to be some switch, as to allow a certain action like knife to create ngnons or stay far away from them, or Ngons as a whole, I'd say it's an improvement. Otherwise, well you may have more options, but you have to check more often to make sure your mesh is still clean.
Gustav Göransson
Post by Gustav Göransson »
FreakyDude wrote:It's easier when you cut. Sure you may have to clean up some new verts afterwards, but that often also goes for Ngon modeling.
I would say the opposite, having Ngons would make cutting easier, it adds more freedom, don't add unwanted geometry which make the clean up process easier.
Which application have you used, which creates huge weird ngons and verts closely to each other without you doing it? I'm just courius.
And not talk about all benifits Ngons bring to mechanical and non sub-D modeling. And all the new tools the B-mesh will bring
Vote for N-gons vote for freedom =)
