Building with GCC under Cygwin SCons is generating the following.Michel wrote:What exactly are the problems you get? We're currently doing some major overhaul of the SCons build system. Any error you currently get may be helpful for improvements in the current overhaul.
Code: Select all
Running makesdna at debug level 0
Program version: $Id: makesdna.c,v 1.8 2004/03/20 22:55:38 zuster Exp $
Can't read file source/blender/makesdna/DNA_listBase.h
scons: *** [/home/mame/build/build/cygwin/source/blender/makesdna/intern/dna.c]
Error 1
scons: building terminated because of errors.
Cygwin is installed with the full package. All components are default installation. SCons was built and installed from the downloaded tarball under Cygwin.
