compiling problems with windows me and cygwin
hey everyone, I am attempting to compile blender with cygwin. You need not point me to Appleman's tut, I am following it currently. I installed cygwin, with all the packages advised, i got the cvs, i tried to "make" but it failed after about 20 minutes with what seem to be memory errors. I can't find any blender specific terms in the error readout, nothing to help me identify a problem area in the source.
I can provide any information needed.
my stats:
PIII 733 (zoom!)
128 mB ram, usually 192 mB, but apparently one is not being detected.
Win Me (not my choice, family computer)
I really want to do some work on the sources and get some personal daily builds. Thanks, SamAdam
my stats:
PIII 733 (zoom!)
Knowing what the error msgs actually are helps in debugging a problem. This is a general rule.what seem to be memory errors.
/me guesses Win ME is running out of system resources. If you are getting memory errors, it has nothing to do with Blender.
Try shutting down Word, Explorer, AIM, Unreal, and all the other things you are running when you compile.
The fact that one of your memory sticks is not being detected does not sound good.
I did a cygwin compilation too yesterday .
p4 at 3.2ghz
1 giga ram
winxp pro
Results:
====> make all in source/gameengine/GamePlayer/common
g++ -c -DUSE_SUMO_SOLID -pipe -mno-cygwin -mwindows -DNDEBUG -O2 -Wall -Wno-reor
der -DFREE_WINDOWS -I./ -I../../../blender/blenkernel -I../../../blender/blenlo
ader -I../../../blender/blenlib -I../../../blender/imbuf -I../../../blender/make
sdna -I../../../kernel/gen_system -I/home/JM/bf-blender/blender/../lib/windows/g
uardedalloc/include -I/home/JM/bf-blender/blender/source/gameengine/Physics/Sumo
/Fuzzics/include -I/home/JM/bf-blender/blender/../lib/windows/string/include
-I/home/JM/bf-blender/blender/../lib/windows/moto/include -I/home/JM/bf-blender
/blender/source/gameengine/Physics/Sumo/include -I/home/JM/bf-blender/blender/..
/lib/windows/gcc/solid/include -I/home/JM/bf-blender/blender/../lib/windows/pyth
on/include/python2.3 -I/home/JM/bf-blender/blender/../lib/windows/bmfont/include
-I/home/JM/bf-blender/blender/../lib/windows/SoundSystem/include -I../../../gam
eengine/Converter -I../../../gameengine/Expressions -I../../../gameengine/GameLo
gic -I../../../gameengine/Converter -I../../../gameengine/Ketsji -I../../../game
engine/Ketsji/KXNetwork -I../../../gameengine/Network -I../../../gameengine/Netw
ork/LoopBackNetwork -I../../../gameengine/Rasterizer -I../../../gameengine/Scene
Graph -I../../../gameengine/Rasterizer/RAS_OpenGLRasterizer -I../../../gameengin
e/Physics/Sumo -I../../../gameengine/Physics/common GPC_Canvas.cpp -o /home/JM/b
f-blender/blender/obj/windows/gameengine/GamePlayer/common/GPC_Canvas.o
GPC_Canvas.cpp:41:17: png.h: No such file or directory
In file included from GPC_Canvas.cpp:44:
GPC_Canvas.h:41: warning: ignoring #pragma warning
GPC_Canvas.cpp: In member function `virtual void
GPC_Canvas::MakeScreenShot(const char*)':
GPC_Canvas.cpp:383: error: `png_structp' undeclared (first use this function)
GPC_Canvas.cpp:383: error: (Each undeclared identifier is reported only once
for each function it appears in.)
GPC_Canvas.cpp:383: error: parse error before `;' token
GPC_Canvas.cpp:384: error: `png_infop' undeclared (first use this function)
GPC_Canvas.cpp:386: error: `png_bytepp' undeclared (first use this function)
GPC_Canvas.cpp:386: error: parse error before `=' token
GPC_Canvas.cpp:387: error: `PNG_COLOR_TYPE_RGB' undeclared (first use this
function)
GPC_Canvas.cpp:390: error: `png_ptr' undeclared (first use this function)
GPC_Canvas.cpp:390: error: `PNG_LIBPNG_VER_STRING' undeclared (first use this
function)
GPC_Canvas.cpp:390: error: `png_create_write_struct' undeclared (first use this
function)
GPC_Canvas.cpp:397: error: `info_ptr' undeclared (first use this function)
GPC_Canvas.cpp:397: error: `png_create_info_struct' undeclared (first use this
function)
GPC_Canvas.cpp:400: error: `png_infopp' undeclared (first use this function)
GPC_Canvas.cpp:400: error: parse error before `__null'
GPC_Canvas.cpp:405: error: `png_jmpbuf' undeclared (first use this function)
GPC_Canvas.cpp:405: error: `setjmp' undeclared (first use this function)
GPC_Canvas.cpp:406: error: `png_destroy_write_struct' undeclared (first use
this function)
GPC_Canvas.cpp:408: error: `row_pointers' undeclared (first use this function)
GPC_Canvas.cpp:431: error: `longjmp' undeclared (first use this function)
GPC_Canvas.cpp:434: error: `png_init_io' undeclared (first use this function)
GPC_Canvas.cpp:455: error: `PNG_INTERLACE_NONE' undeclared (first use this
function)
GPC_Canvas.cpp:456: error: `PNG_COMPRESSION_TYPE_DEFAULT' undeclared (first use
this function)
GPC_Canvas.cpp:457: error: `PNG_FILTER_TYPE_DEFAULT' undeclared (first use this
function)
GPC_Canvas.cpp:457: error: `png_set_IHDR' undeclared (first use this function)
GPC_Canvas.cpp:460: error: `png_write_info' undeclared (first use this
function)
GPC_Canvas.cpp:463: error: `png_bytep' undeclared (first use this function)
GPC_Canvas.cpp:463: error: parse error before `[' token
GPC_Canvas.cpp:477: error: `png_write_image' undeclared (first use this
function)
GPC_Canvas.cpp:480: error: `png_write_end' undeclared (first use this function)
make[4]: *** [/home/JM/bf-blender/blender/obj/windows/gameengine/GamePlayer/comm
on/GPC_Canvas.o] Error 1
make[3]: *** [all] Error 1
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make: *** [all] Error 1
p4 at 3.2ghz
1 giga ram
winxp pro
Results:
function)
function)
function)
function)
this function)
function)
this function)
function)
function)
function)
Zoo-3D.Blender, Ze French-Speaking Community SKB My french book about Blender.
okay.
about the ram: my computer is strange like that. sometimes the full 256 mb appears, sometimes not. Sometimes my processor is clocked differently. About every other time I boot up I get a different proc speed. Yesterday my 733 booted up at 900 mhz. most of the time it is around 866.
idk...
i think that closing the other program I had running might work.
i will check back later.
idk...
No problem if I delete in this file all the refs to the png.h . It results a compilation without screen saver for the gameengine.stiv wrote:Search thru the compile output looking for lines that say 'No such file or directory'. Either you do not have something installed and the file is missing or you do not have the include paths properly set and make cannot find it.
If I correct the path to " png.h" then error are multplied
by 4... It seems that the script is C compliant but not C++.
okay, well, here is what I got after I tried to close all the other applications
that is just what is visible in my command console.
any thoughts?
i got a lot farther than before.
Code: Select all
function)
this function)
function)
function)
function)
make[4]: *** [/cygdrive/c/blender/blender/obj/windows/gameengine/GamePlayer/comm
admin@computer /cygdrive/c/blender/blender
any thoughts?
Open the GPC_Canvas.cpp file and remove the two last active functions .
which of these should i delete jms?
Code: Select all
// write the file header information
png_write_info(png_ptr, info_ptr);
// allocate memory for an array of row-pointers
row_pointers = new (png_bytep) [(GetHeight() * sizeof(png_bytep))];
if (!row_pointers)
std::cout << "Cannot allocate row-pointers array" << std::endl;
longjmp(png_jmpbuf(png_ptr), 1);
// set the individual row-pointers to point at the correct offsets
for (i = 0; i < GetHeight(); i++) {
row_pointers[GetHeight()-1-i] = (png_bytep)
((unsigned char *)pixels + (i * GetWidth()) * bytesperpixel * sizeof(unsigned char));
// write out the entire image data in one call
png_write_image(png_ptr, row_pointers);
// write the additional chunks to the PNG file (not really needed)
png_write_end(png_ptr, info_ptr);
// clean up
delete [] (pixels);
delete [] (row_pointers);
png_destroy_write_struct(&png_ptr, &info_ptr);
if (fp)
fflush(fp);
fclose(fp);
Code: Select all
$ make
====> make all in blender/extern
====> make all in extern/qhull/src
/cygdrive/c/blender/blender/source/tools/cygwin/cl_wrapper.pl -c -DGAMEBLENDER=1
-DUSE_SUMO_SOLID /MT -DNDEBUG /O2 -I../include -DWIN32 -D_WIN32 -D__WIN32 -D_M_
IX86 -I"/cygdrive/c/Program Files/Microsoft Visual Studio/VC98/include" user.c -
o /cygdrive/c/blender/blender/obj/windows/extern/qhull/user.o
cl: not found
make[2]: *** [/cygdrive/c/blender/blender/obj/windows/extern/qhull/user.o] Error
127
- Site Admin
Looks like some path is wrong, since cl.exe is not found...SamAdam wrote:any ideas?Code: Select all
cl: not found
/Nathan
in fact, we have just to copy :jms wrote:Open the GPC_Canvas.cpp file and remove the two last active functions .
..\bf-blender\lib\windows\png\include\ - png.h - pngconf.h
..\bf-blender\lib\windows\zlib\include\ - zlib.h - zconf.h
in :
..\bf-blender\blender\source\gameengine\GamePlayer\common\
(found by laume on a french forum)
- Site Admin
i tried compiling the 10/27 build and I got the same failure. I don't know what it is looking for in the microsoft visual studio area, i don't have any of that installed. I was just about to get to work, too. Any ideas?SamAdam wrote:admin@computer /cygdrive/c/blender/blender
$ make
cl: not found
127
any ideas?
and can someone give me a quick tut on applying patches?
