Page 2 of 2
Posted: Wed Oct 27, 2004 12:34 pm
by butelo
I´ve got exactly the same problems since yesterday, I compile CVS almost every day with cygwin perfectly, without any changes suddenly didn´t work, any suggestions or ideas? The compilation log is the same as above...
Posted: Thu Oct 28, 2004 10:21 pm
by Kenden
I have compiled with scons and cygwin with no problems, but when I start the build, I get the error:
"libpng.dll was not found".
Scons doesn't build the game engine with cygwin by default, and it seems that only the makefile has been fixed at the moment:
http://projects.blender.org/viewcvs/vie ... bf-blender
Could this have something to do?
(code is from 28-10-04)
thanks,
kenden
Posted: Fri Oct 29, 2004 1:00 am
by jesterKing
I committed a fix for scons already way before the makefiles were updated, related to Kesters screenshot fix.
/Nathan
Posted: Fri Oct 29, 2004 3:24 pm
by Kenden
Thanks jesterKing, I should have looked better in the archives.
I have just compiled with 'cygwin' and 'make' with no problem, and the build runs fine.
So I am wondering if there isn't a problem with the scons configuration for cygwin. I have saved the error message, when I launch blender.exe, I get:
blender.exe - Unable To Locate Component
This application has failed to start because libpng.dll was not found. Re-installing the application may fix this problem.
OK
Other differences between using 'make' and 'scons':
With make:
- I get a .zip file,
- the blender.exe has the blender icon
- there are files not present with scons:
* Help (shortcut to http://www.blender3d.org/Support/)
* Python23.zip
* zlib.pyd
* release_226.txt
* release_227.txt
* release_228.txt
* release_228a.txt
* release_228c.txt
* release_230.txt
* release_231.txt
* release_232.txt
* release_233.txt
* release_233a.txt
With scons:
- I get a tar.gz file,
- the blender.exe has no icon, just the 'Default Application' icon,
Does somebody else has the same symptoms when using scons?
thanks,
kenden
PS: I know scons is still being worked on, just trying to help iron bugs.
