compiling GamePlayer
Doc_Holiday
Post by Doc_Holiday »
I made my first 2.36 Build with Cygwin and Win2k. All fine till now. ;) But how do i compile the GamePlayer? All i get is the Blender.exe.
Thanx, Doc
Sutabi
Post by Sutabi »
The gameblender in built into the .exe... there is an option you can set in userdef.mk but I forgot the option =_= sorry. but search the source for any text of GamePlayer you might find the definition in there
z3r0_d
Post by z3r0_d »
# To build blender without having to build the plugin, etc
#export NAN_JUST_BLENDERDYNAMIC=true
... that is all I could find, it used to be built by default but isn't any more
Doc_Holiday
Ok, made a 'user-def.mk' with export NAN_JUST_BLENDERDYNAMIC=true ... no, won't work. :( Cygwin give an Error and breaks:
Code: Select all
cl: not found
make[5]: *** [/cygdrive/c/bf-blender/blender/obj/windows/gameengine/GamePlayer/n
etscape/src/Blender3DPlugin.o] Error 127
Do i need something special?
z3r0_d
Post by z3r0_d »
I compile in cygwin
my user-def.mk has only two non-commented lines
Code: Select all
export FREE_WINDOWS=true
export CFLAGS += -DGAMEBLENDER=1
the second one is probably redundant, but the blenderplayer seems to be built
I'm trying a "make clean all" now to be sure. config.opts [scons build system] is a lot more clear on the build settings than user-def.mk
edit:
blenderplayer isn't built, I'm not sure how I did it anymore
Doc_Holiday
Nobody knows that? :shock: I'm confused. If there is a official Release, how do they get the GamePlayer :?:
Doc
SirDude
Post by SirDude »
To build without the gameplayer you want to set:
export NAN_NO_OPENAL=true
or just set: export NAN_NO_KETSJI=true
So to build the gameplayer you want to make sure those all are not set.
Doc_Holiday
No, i don't get it to work. I give up! :(
