New constraints
dogobe
New constraints
Post by dogobe »
I am in the process of finishing two new constraints,
(1) Copy VertexGroup Location
(2) Track to VertexGroup
... basically allowing you to parent/track to a specified vertex position.
Are these things that other people would find useful? Should I be looking in to getting this checked in to CVS?
I am also very new to the coding process so if some one would like to fast track me that would help a lot.
Thanks
z3r0_d
Post by z3r0_d »
vertex parents exist
and with 3 verts selected you can parent to a face
... you could track to that object...
am I missing something or is this already possible?
dogobe
Post by dogobe »
... Doh! That's a method I have not used before - I am an old school geeza. This feature passed me by while I was sleeping or something.
I tried a simple softbody cloth and parented an empty to the corner face of the cloth using the vertext parent method. As long a I chose a single face I got good results.
I think I can use this method to get the results I need - basically to rig the automated animation of dredlocks - beter deformed using an armature than softbody (too jelly like). Basically map the armature tracking to some empties parented on to a softbody scalp/hat. I'll post my results on elysiun - vertex parenting could do with a little more promotion.
Cool I've learnt something new. Two things (1) how to use vertext parents (2) how to implement constraints.
... If anyone has a meaningful constraint that needs implementing I could consider doing it.
Very many thanks z3r0_d
env
Post by env »
Dogobe, I think that your two new constrains could be really useful anyway, at least with constrains the influence can be animated by ipos.
If you want a suggestion for one other constrain, what about a "shaking" effect constrain? I'll try to explain myself as better as I can:
- a bone is created for a fat vertex group of the mesh; rotating this bone simulates the jiggle of the fat but, you have to key the action of "shaking" by hand every time it's needed;
- so, instead you could apply a "shaking" constrain to this bone: every time a "target" bone hit the "ground" (and the floor constrain could be useful for this) the "shaking" bone automatically has a "shaking" :) ; in the constrain panel you can set the speed and the duration of the effect.
Don't know if this is clear.
EnV
jesterKing
Site Admin
Re: New constraints
Post by jesterKing »
dogobe wrote: Are these things that other people would find useful? Should I be looking in to getting this checked in to CVS?
Thanks
In the very least you could add it to the patch tracker (< link). Apart from that, do join the coders channel on freenode (#blendercoders), and ask people for input/review.
http://www.blender3d.org/cms/Get_Involved.233.0.html has also a bit of info.
/Nathan
