Latest linux CVS compile gives error (scons release)
Napoleon
Post by Napoleon »
Blender compiles alright but when i use "scons release" i get this error message:
il -lstdc++ -lGL -lGLU
/usr/lib/python2.4/config/libpython2.4.a(posixmodule.o): In function `posix_tmpnam':
: warning: the use of `tmpnam_r' is dangerous, better use `mkstemp'
/usr/lib/python2.4/config/libpython2.4.a(posixmodule.o): In function `posix_tempnam':
: warning: the use of `tempnam' is dangerous, better use `mkstemp'
zipit(["blenderrelease"], ["blender"])
scons: *** [blenderrelease] Exception
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/Taskmaster.py", line 101, in execute
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/Node/__init__.py", line 201, in build
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/Executor.py", line 115, in __call__
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/Action.py", line 243, in __call__
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/Action.py", line 512, in execute
File "/home/napoleon/blenderdev/blender/tools/scons/bs/bs_arc.py", line 129, in zipit
if bs_dirs.preparedist()==0:
File "/home/napoleon/blenderdev/blender/tools/scons/bs/bs_dirs.py", line 103, in preparedist
shutil.copy("text/" + reltext, "../dist/" + reltext)
File "/usr/lib/python2.4/shutil.py", line 81, in copy
copyfile(src, dst)
File "/usr/lib/python2.4/shutil.py", line 47, in copyfile
fsrc = open(src, 'rb')
IOError: [Errno 2] No such file or directory: 'text/release_240-alpha1.txt'
scons: building terminated because of errors.
IOError: [Errno 2] No such file or directory: './../build/linux2/scons-signatures.dblite':
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/Script/__init__.py", line 1103:
None
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/Script/__init__.py", line 1097:
None
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/Script/__init__.py", line 1063:
None
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/SConsign.py", line 49:
None
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/SConsign.py", line 117:
None
File "/home/damir/cvsARCH/extra/devel/scons/pkg/usr/lib/python2.4/site-packages/SCons/dblite.py", line 66:
None
Exception exceptions.TypeError: "'NoneType' object is not callable" in <bound method dblite.__del__ of <SCons.dblite.dblite instance at 0xb7a5194c>> ignored
Thanks for your aniticipated help.
kidb
Re: Latest linux CVS compile gives error (scons release)
Post by kidb »
Napoleon wrote: IOError: [Errno 2] No such file or directory: 'text/release_240-alpha1.txt'
Touch it.
touch release/text/release_240-alpha1.txt
Napoleon
Post by Napoleon »
hey kidb thanks. Your tip worked :D. Cheers.
