OS X Project Builder
Tubal_C
Post by Tubal_C »
Is there any progress being made with Project Builder ?
Is compiling OS X version better off being done with pbxbuild / Project Builder or plain Ol' command line GCC? How was the original OS X port compiled? Code Warrior, Project Builder or gcc?
Those that are working on the OS X build please drop me a line.
brojohnson@comcast.net I can also be reached at brojohnson on AIM and I'm usually in #blenderchat as powermacg4
SirDude
Post by SirDude »
I think everyone is using the Makefile system that is in cvs01
Download cvs01 and take a look at the readme its pretty
straight forward.
If you have any questions on it swing by #blendersauce and ask
your questions :)
SirDude
Post by SirDude »
oops its not called cvs01 anymore its bf-blender sorry :)
kattkieru
Post by kattkieru »
On the committers list there is progress being made every so often, with new versions being comitted to the CVS server. I've yet to compile the whole thing yet, but the closest I've gotten thus far has been with the command line. So far, the project builder files don't work on my system.
kurzog
OS X
Post by kurzog »
Are there the beginnings of Project Builder files in the CVS for downloading? I'd also like to get rolling with being able to compile Blender without using the commandline...
Thanks!
Money_YaY!
Post by Money_YaY! »
Anything else alive here? Please say somebody has done the impossible
^v^
effeuno
Post by effeuno »
Trying to compile OSX version of Blender using autoconfigure I got the same error reported by Velik in
http://www.blender.org/modules.php?op=m ... opic&t=889
I cant solve the problem but I hope the next release will fix it.
F1
Bischofftep
Some Help
Post by Bischofftep »
Hello:
Using a bash script given to me by one of the more experienced Blender coders, I have had no problem successfully compiling using the command line. The script is simple:
Code: Select all
#!/bin/bash
rm -f /tmp/.nanguess
export MAKE=make
export NANBLENDERHOME="/Users/developer/Projects/blender"
export OS="darwin"
export NAN_NSPR="/Users/developer/Projects/nspr422-Darwin6.4"
export MAKEFLAGS="-w -I $NANBLENDERHOME/source --no-print-directory"
export HMAKE="$NANBLENDERHOME/source/tools/hmake/hmake"
echo
echo NANBLENDERHOME : ${NANBLENDERHOME}
echo OS : ${OS}
export NAN_PYTHON="/Library/Frameworks/Python.framework/Versions/2.2"
$HMAKE -C extern/
if [ $? -eq 0 ]; then
	$HMAKE -C intern/
		$HMAKE -C source/
	fi
fi
Naturally, you'll need to change the paths listed here... but if you do so you won't have to edit paths anywhere else. Then just CD into the blender directory and type "bash ../makeblenderscript" and it'll do its thing.
I also have a working ProjectBuilder with Maarten's help, but at the moment the binary it builds is NOT the same as from the command line by a LONG shot, and there are a lot of problems with it that I haven't yet ironed out. It works... but the code isn't as stable (or as small...) as the command line script above generates.
Hope it helps: if Maarten agrees that my PB file is usable he'll commit it to the CVS soon.
-Bischofftep
kurzog
Re: Some Help
Post by kurzog »
Bischofftep wrote: I also have a working ProjectBuilder with Maarten's help, but at the moment the binary it builds is NOT the same as from the command line by a LONG shot, and there are a lot of problems with it that I haven't yet ironed out. It works... but the code isn't as stable (or as small...) as the command line script above generates.
-Bischofftep
I look forward to that - thanks!
kurzog
Post by kurzog »
Has there been any progress with the PB compile for OS X?
If yes, where can I get it.. if no - can I have what you have so I can attempt to work on it as well?
Thanks!
SirDude
Post by SirDude »
All of the Projectbuilder files are in the cvs tree.
under make/pb_2_0_1 If you have any patches
email them to the bf-committers mailling list and we'll
apply them.
kurzog
Post by kurzog »
Thanks!
kurzog
Post by kurzog »
Sorry to be a bother (again), but what is the state of the PB port?
SirDude
Post by SirDude »
No idea really sorry. I've never used it.
I'd be glad to help you with the nan makefiles
and or the autoconf stuff though if you have questions
there.
kurzog
Post by kurzog »
Thanks again, SirDude.. I may bug you again.. ;)
