Including flags in the build command.
tcp
Post by tcp » Tue Dec 20, 2005 1:55 pm
Hello,
I need to insert 2 extra flags to compile static blender (-lXxf86vm -ldrm).
Where can I include them (which SConscript or config file?) ?
Thanks.
russose
Post by russose » Wed Dec 21, 2005 9:42 am
Hallo tcp,
You have to update the Sconscript file in blender/source with your extra flag (look at your specific platform setting, there is something like EXTRA_FLAG= []).
But then, you need to delete the config.opt file and scons will generate a good one with your extra flags.
It should then work.
Salvatore
Michel
Location: Somewhere below the rivers in Holland (but not Limburg)
Post by Michel » Wed Dec 21, 2005 3:42 pm
russose wrote:You have to update the Sconscript file in blender/source with your extra flag (look at your specific platform setting, there is something like EXTRA_FLAG= []).
Erm, the config.opts file is exactly for specifying user configurable options so that you don't have to go through the SConscript file. Just add the needed flags to the EXTRA_FLAG in config.opts.
If that doesn't work, then you've found a bug.
Michel
You can have one of two things: Progress or Progress Reports.
