SOC Sculpt Build errors
JA-forreal
Post by JA-forreal »
I just finished building a SOC Sculpt build on Ubuntu Dapper. It seemed to compile ok. When I ran it in a terminal I got this error report-
Compiled with Python version 2.4.
Checking for installed Python... got it!
X Error of failed request:  BadDevice, invalid or uninitialized input device
  Major opcode of failed request:  146 (XInputExtension)
  Minor opcode of failed request:  3 (X_OpenDevice)
  Serial number of failed request:  24
  Current serial number in output stream:  24
JA-forreal
I chmod +x 'd the executable but it won't run. Am I missing something?
kidb
Re: SOC Sculpt Build errors
Post by kidb »
Edited the wrong post. Here should be something like dpkg -l libxi. But it is wrong anyway.
JA-forreal
kidb I got this in the console-
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Installed/Config-files/Unpacked/Failed-config/Half-installed
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err: uppercase=bad)
||/ Name           Version        Description
ii  libxi-dev      1.0.0-0ubuntu3 X11 Input extension library (development hea
ii  libxi6         1.0.0-0ubuntu3 X11 Input extension library
ii  libxi6-dbg     1.0.0-0ubuntu3 X11 Input extension library (debug package)
un  libxine-extrac <none>         (no description available)
ii  libxine-main1  1.1.1+ubuntu2- the xine video/media player library, binary
un  libxine1       <none>         (no description available)
un  libxine1c2     <none>         (no description available)
ii  libxinerama1   1.0.1-0ubuntu2 X11 Xinerama extension library
What does this mean exactly? And what is the relationship to by build of Blender-Sculpt not running? Thanks.
kidb
Post by kidb »
There is support for an Xinput-Device (tablet) in the latest code. I unplugged my tablet and get now the same error. Solution: Buy a tablet. :-)
I will look if i can add spaceball-support, but only for linux.
