Compiling Error : Checking FreeAlut... failed
Dave Ridic
Post by Dave Ridic »
I'm trying to install blender with scons but... There's a strange error about the freealut lib.
I can't fix it alone !
I send to you an extract of the compiling history :
Compiling ==> 'SND_OpenALDevice.cpp'
intern/SoundSystem/openal/SND_OpenALDevice.cpp:48:21: AL/alut.h: No such file or directory
intern/SoundSystem/openal/SND_OpenALDevice.cpp: In member function `virtual SND_ WaveSlot* SND_OpenALDevice::LoadSample(const STR_String&, void*, int)':
intern/SoundSystem/openal/SND_OpenALDevice.cpp:433: error: `alutLoadWAVMemory' u ndeclared (first use this function)
intern/SoundSystem/openal/SND_OpenALDevice.cpp:433: error: (Each undeclared iden tifier is reported only once for each function it appears in.)
intern/SoundSystem/openal/SND_OpenALDevice.cpp:448: error: `alutLoadWAVFile' und eclared (first use this function)
intern/SoundSystem/openal/SND_OpenALDevice.cpp:476: error: `alutUnloadWAV' undec lared (first use this function)
scons: *** [/root/Desktop/Blender/build/linux2/intern/SoundSystem/openal/SND_Ope nALDevice.o] Error 1
scons: building terminated because of errors.
If somebody has an idea... please, help me.
I thank you in advance
Dave
Les plus belles choses existent déjà...
lguillaume
Post by lguillaume »
Do you have openal source installed on your system?
If you want you can compile without this, in your blender source root there is a directory called config, inside copy linux2-config.py in the blender source root, rename it user-config.py
In this file you can setup what you want, and for openal set false to the line : WITH_BF_OPENAL =
Now you can continu to compile
Dave Ridic
Well, this fixed the first problem... Thank you
But now, there is a hurricane of errors during the BPY_interface.c compilation...
This is the firt five errors :
Compiling ==> 'BPY_interface.c'
source/blender/python/BPY_interface.c:34:20: Python.h: No such file or directory
source/blender/python/BPY_interface.c:36:59: compile.h: No such file or directory
source/blender/python/BPY_interface.c:37:58: eval.h: No such file or directory
In file included from source/blender/python/BPY_interface.c:56:
source/blender/python/api2_2x/constant.h:36:20: Python.h: No such file or directory
source/blender/python/api2_2x/constant.h:41: error: syntax error before "constant_Type"
Do you know what the problem is?
lguillaume
Do you download the lib directory in CVS or the dev package of python, I don't know I compile under windows
Dave Ridic
:) ... It's already installed... I think...
Dave Ridic
I use Synaptic... So I think I downloaded the dev package... Is that a problem ?
Dave Ridic
Je crois que tu es français... n'est-ce pas ?
C'est tout de même mieux de parler dans sa langue maternelle... :D
Bon... Lorsque j'ai installé Linux, Python était déjà installé... Faudrait-il le réinstaller autrement ? J'avoue ne pas bien comprendre pourquoi tout est si compliqué...
Well... When I installed Linux on my PC, Python was already installed... Should I install it again ? You know, really, I don't understand why it is so complex...
lguillaume
Oui je suis français, mais ça n'aidera pas les autres et les non francophones ne pourront pas t'aidés.
Python est installé mais peut être pas les paquets pour les développeurs, regarde si tu as le paquet dev de python d'installé.
Et je n'ai jamais utilisé synaptic donc peut pas t'aider pour le choix du paquet.
Python is installed but perhaps not the dev package, look to see if you have it.
I never used Synaptic so I can't help you for what package you have to take.
kidb
Post by kidb »
If you are on debian/ubuntu an apt-get build-dep blender will help a lot. apt-get install apt-file, apt-file update, apt-file search al.h will find libalut-dev.
you should have too, libopenal-del, libsdl1.2-dev.
angel75
Post by angel75 »
Dave Ridic
Thank you for your help...
You were right, I have not installed the python-dev package.
This error was fixed. But there is an other compiling error about openEXR library...
But I think I am able to fix it by myself... thanks to you.
I hope you'll be here if there is an other problem. :wink:
Thank you very much guys
