How to run blender from a different java based application?
Sikha Devi
Post by Sikha Devi »
I want to run blender from a different java based application . I have created blender menu in the menubar of that application. When i click the 'run' menuitem in the blender menu the default scene of blender should come so that the i can start working in blender.I have placed blender-2.42a-linux-glibc232-py24-i386-static directory which is used to run blender in my system, in a directory 'tools' which is under the directory where all the files of that application resides . I have used this coding
public static void runblender () {
String appinterfaceExePath = Utils.USER_DIR + Utils.FILE_SEPARATOR +"tools"+ Utils.FILE_SEPARATOR +"blender-2.42a-linux-glibc232-py24-i386-static" + . + Utils.FILE_SEPARATOR + "blender";
Runtime r = Runtime.getRuntime():
r.exec(appinterfaceExePath):
} But blender does not run in this way.
Will u plz provide me the actual java coding for it ?
Thanking you.
Sikha Devi.
S.Devi
tsodzil
Post by tsodzil »
Have you dried to debug the path to the blender-binary?
Also surround the runtime call with a try+catch. so that a exception is thrown if something does not work.
simonharvey
Post by simonharvey »
tsodzil wrote:Have you dried to debug the path to the blender-binary?
Sorry, but I thought that was quite funny. I usually debug my code the second ive gotten out of the shower.
Kind Regards
Simon Harvey
Edit: :D.
Sikha Devi
Sorry! I couldnot understand the meaning of your reply. Will you plz explain how can i debug the path to the blender binary? I am working in linux 2.6.12-12mdk.
Thanking you.
Sikha Devi
S.Devi
stiv
Post by stiv »
It has been a while since I was a victim of Java, but my random guessing is there is something missing from the runtime setup like a home directory or an environment variable like $HOME.
Running blender with the -d flag and capturing the output might give clues.
Sikha Devi
How to run blender from a java application ?
I runned blender in this way
./blender -d and got these informations args[0]=./blender
args[1]= -d
I have coded in this way to run blender from the menubar of a diffrent java based application
public static void runblender{
String cmd="./blender";
String cmds[] = {"/home/sda_tr3/incad_new/tools/blender-2.42a-l
inux-glibc232-py24-i386-static","./blender" };
String envp[]=null;
String dir= Utils.USER_DIR + Utils.FILE_SEPARATOR +"tools"+ U
tils.FILE_SEPARATOR +"blender-2.42a-linux-glibc232-py24-i386-static" ;
File file=new File(dir ) ;
try
Runtime r= Runtime.getRuntime();
Process process = r.exec(cmd,null,file);
catch(IOException e) {
e.printStackTrace();
But it is showing io exception . Am i wrong in using the actual form of exec method ?Should i set environment variables to the values where the menubarclient.xml, the xml file where the menubar items of the java application are set or to the blender -2.42a-linux-glibc232-py24-i386-static directory ? Plz guide me.
Thanking you
Sikha Devi
S.Devi
