applying Logic Properties to many objects at once
detox
Post by detox »
Hello, this is my first post to the Blender forums. First I have to say Blender is a fantastic tool and I'm having quite a bit of fun with it.
I have a question. Is there a way to apply/add Logic Properties to many objects at one time? Currently I select an object in object mode, press [F4] to bring the Logic panel up if it's not already, then click the big "Add Property" button, then enter my logic property: type, name, value.
My problem is that if I select many objects at once using for instance in object mode, the property I add is only applied to the last object selected and not the whole set of selected objects.
If I cannot apply a property to many objects at once is their a way to copy logic properties?
Thank you
Caronte
Post by Caronte »
Use Ctrl+C to copy from the last selected object to another one (or several).
For beginner questions you can get better support in the blenderartists.org forums.
Caronte.
http://www.nicodigital.com
detox
Post by detox »
Thank you for the reply, it was a great help. I will move over to the other forum.
