Ok this is gonna sound REALLY weird but...
LazyCoder
Post by LazyCoder »
Whenever I have 10000 static particles, my computer makes a strange noise every time blender redraws the view. Like I'll rotate the camera and I'll keep hearing this beeping noise coming from inside my computer, not from the speakers.
When I turn off static, or lower the amount below 2000 I can't hear the noise. Above 2000, the more particles I have, the louder the noise.
My specs:
- 2.33 GHz dual core intel
- 2048 MB memory
- 256 MB ATI radeon mobility X1800
So freakin annoying.
joeri
Post by joeri »
What kind of noise? Is it the gfx-card fan speeding up but grinding because it's a bit old or dirty?
BeBraw
Post by BeBraw »
That sounds like swap memory (hard disk) in use for me. Though with those specs it seems a bit strange but it may be a reason. You did not mention which operating system you are using. This information might enlighten the situation a bit. Other systems than Windows generally can access more memory (>1 GB iirc) in case of Blender. There's an experimental patch at the tracker to remedy this limitation though.
indigomonkey
Post by indigomonkey »
LazyCoder - don't worry, you're not entirely alone in peculiar noises happening! When I drag nodes around, I get a hissing noise coming through the speakers... I think computers just like to keep you amused really!
Koba
Post by Koba »
Same thing here!
It is a wierd crackle as I rotate round the 3D view at times. Stop moving and it stops crackling. That said, I've noticed the same thing with some command line programs too - is the command line/console is generating loads of output I can hear it with my speakers turned off!
No it isn't the disk swapping cause I know that sound!
Koba
LazyCoder
Post by LazyCoder »
... and if you get enough of them it almost sounds like crickets? lol
I'm on Windows XP, and I assume it's sp2 because I got the computer after sp2 was released.
So there's nothing really wrong with my computer? It's just kind of annoying that's all.
Dani
Post by Dani »
This happens to me on my ATI notebook. It has always done this whenever the gfx chip has a lot to handle. it goes like "zzzzzzzzzzzzzzz". Hey that's a good imitation!
Dani
