Inconsistencies in the functionnality of the bevel modifier.
iaminnocent
Post by iaminnocent »
Sorry to put this here but I couldn't find out who developped the bevel modifier.
I guess that the following was intended. Nevertheless it seems that the users are often confulsed by it:
- it is impossible to add any bevel weight to an edge using the Ctrl-Shift-E shortcut when we are in vertex selection mode, even if an edge has been properly selected using its two vertices. If one uses the menu though, bevel weight can be added. Users wish that it could be possible using the shortcut too.
- when adding weight to the vertices only, shouldn't there be an entry in the menu under Mesh > Vertices ? The idea of looking for it under 'Edges' doesn't come to everybody.
Thanks for your time.
