2.54 beta Exporting 3ds couses errors
ninodelafortuna
Post by ninodelafortuna »
Hello i'm new.
I tried to export model from blender 2.54beta to 3ds but i get this kind of error:
File "C:\Users\Sebastian\AppData\Roaming\Blender Foundation\Blender\2.54\scrip
ts\op\io_scene_3ds\__init__.py", line 58, in execute
return io_scene_3ds.export_3ds.save(self, context, **self.properties)
ts\op\io_scene_3ds\export_3ds.py", line 969, in save
object_info.add_subchunk(make_material_chunk(mat_and_image[0], mat_and_image
[1]))
ts\op\io_scene_3ds\export_3ds.py", line 473, in make_material_chunk
material_chunk.add_subchunk(make_material_texture_chunk(MATMAP, images))
ts\op\io_scene_3ds\export_3ds.py", line 440, in make_material_texture_chunk
add_image(image)
ts\op\io_scene_3ds\export_3ds.py", line 434, in add_image
filename = os.path.basename(image.filepath)
NameError: global name 'os' is not defined
Can anybody tell me if it's common problem or i did something wrong?
My model is a simple object with default material and texture (jpg image 512x512 ).
Problem doesn't exist when I remove material.
Maybe i have to install Python or something. My current version is Python 2.66 amd64. I'm using Win7 64bit.
tushantin
Post by tushantin »
Hmm your best bet would be to ditch the materials and use 3DsMax's material tool. :?
I'm having 3Ds export problems too though (Blender 2.54, Win32 Zip). After exporting all my 4-sided polygons turn to 3-side and quite a lot of normals and vertices shift and separate, forcing me to use Collada format instead (can't seem to export in FBX and OBJ for some reason).
ninodelafortuna
hi tushantin. Thanks for Your advice. I'm importing 3ds files into Away3d/Flash application. I need files to be small. So i can't use collada format.
I solved my problem this way:
- after baking texture I save it to JPG file
- I delete material linked to the Object ( problem exist when object has material)
- then export to 3ds file
- I put source paths to the texture files and 3ds models in a XML file I've created ( simple furniture library )
- in Action Script I load a model and texture separately using XML library
Code: Select all
<?xml version="1.0" encoding="utf-8"?>
<models>
<furnitures name="Sypialnia">
<elem thumb="model_01.jpg" model="model_01.3ds" >
<texture name="Texture 1" src="model_01_tex1.jpg"></texture>
<texture name="Texture 2" src="model_01_tex2.jpg"></texture>
<texture name="Texture 3" src="model_01_tex3.jpg"></texture>
</elem>
<elem thumb="model_02.jpg" model="model_02.3ds" >
<texture name="Texture 1" src="model_02_tex1.jpg"></texture>
<texture name="Texture 2" src="model_02_tex2.jpg"></texture>
<texture name="Texture 3" src="model_02_tex3.jpg"></texture>
</elem>
<elem thumb="model_03.jpg" model="model_03.3ds" >
<texture name="Texture 1" src="model_03_tex1.jpg"></texture>
<texture name="Texture 2" src="model_03_tex2.jpg"></texture>
<texture name="Texture 3" src="model_03_tex3.jpg"></texture>
</elem>
</furnitures>
</models>
It works
