Problem Applying Any Texture or Material to Object
retzev18
Post by retzev18 »
Hi-
I am unable to apply any texture to an object in 2.5. This problem doesn't exist for me in pre-2.5 builds...
When I apply any color or material to an object, (say, the default cube w/ default camera and lamp), and attempt to view w/ "Textured Solid", my object turns white and random faces of the object disappear. No change registers when I render either.. just the untextured cube. Anyone know of a fix for this issue? (Unless I'm doing something terribly wrong...)
Thanks for your help.
Nikprodanov
Post by Nikprodanov »
"Textured Solid" doesn't show the material texture, but rather the image you assign to it in the UV/Image editor. Also if the texture doesn't render, it probably means there are no UV coords or its using a different mapping method like "Generated".
