I have been using the Boolean operations more lately than normal and they are very, very messy. The triangulation of the mesh and the clean up required after a Boolean operation takes more time than actually modelling the object from scratch, on more complex items.
I have used the Boolean features in Lightwave and they are fantastic. Everything reverts to quads and the mesh is incredibly clean after the operation.
Can we get Blender Booleans to this level? If so, it would become one of the more poweful features of Blender and would make my life, and I'm sure, a lot of other peoples lives a lot easier.
BgDM
Better, Cleaner Boolean Operations
Reality is an illusion caused by lack of alcohol.
WHAT!!!? Why not? This needs to be done at some point. I understand that getting a stable version of Blender up and running is paramount first, but this is a key feature that would benefit all users.Timothy wrote:Asfar as I know noone is working on it.
Anyone else have some input into this?
BgDM
I'm working on it, but I'm not having too much success. I was looking at integrating FreeSolid (an implementation of AABB trees) into Blender, but I ran into some problems getting the original package compiled. Apparently some files were missing from the SourceForge distribution. Then I went on vacation and nearly forgot about it, but it's been sitting in the back of my mind ever since. If anyone has any suggestions, I would like to hear them -- as of right now it looks like I don't have enough time or enough skill to really look at making serious, involved modifications to Blender.
I'm not giving up, though, so maybe in the future...
Matt
Matt
IMHO, CSG operations that try to pretend that Blender objects are solids is the wrong way to go.
I'd much rather see the development cycles go to enabling more advanced surface modeling techniques like Curves-on-Surface and Trims.
By projecting/intersecting surfaces to generate UV curve mapping, and then trimming to those curves, one can achieve anything that is doable with "true" CSG boolean operations, and not be limited to "solid geometry" concepts.
It would be wonderful to be able to trim two adjoining surfaces to each other, cut an eye- or button-hole out of a nurbs surface, or carve a spherical depression out of a cube... all of these would be possible with a comprehensive Curves/Trim feature set.
i had a thought that might help with this.
if any ones used quark( the quake level editor) you should know that it uses python plugins for all the tools.
its been some time, but i think the booleans were done this way.
would it be possible to modify those tools into blender.
what would also be good is non-destructive boolean subtraction, i think light wave has it, you put an object on a seperate sub layer to the object, then select subtract or something like that.
