Joining Meshes
Posted: Fri Jun 03, 2011 3:41 pm
by WREF48
OK, Ctr+J joins meshes so they are both editable in edit mode, but in some way they are still independent, like when I drag a vertex close to other mesh it doesn't modify with first mesh, is there any way to make the second mesh respond to first changes?
Re: Joining Meshes
Posted: Sat Jun 04, 2011 1:16 am
by woody730b
WREF48 wrote:OK, Ctr+J joins meshes so they are both editable in edit mode, but in some way they are still independent, like when I drag a vertex close to other mesh it doesn't modify with first mesh, is there any way to make the second mesh respond to first changes?
I'm not entirely sure what you're trying to convey, but it sounds like you want to create 2 meshes, join them together, and modify one to affect the other? If that's the case, then I don't think that is possible with the current blender build. I'm not even sure if there's an alternative build to do that. If this is not what you are trying to do, can you please provide us with some more info.
Posted: Sat Jun 04, 2011 9:33 am
by Nikprodanov
I'm not exactly sure what you want to do, but you probably have to enable Proportional Editing (O-key).
