mirror select
biggoomer
mirror select
Post by biggoomer »
I'm working on creating a body re placer for a game and i'm at the point where I need to texture my model. The model is rather high-poly so marking seams takes quite a long time. I got one side of the body marked but I can't seem to get the other side marked the same way I did the first side. The body is completely symmetrical so I was wondering if there was I tool I could use to mirror the seam from side to the other. The seam right now goes along the left side of the body separating the front from the back.
tl;dr I need a tool that will allow me to duplicate a seam over the x axis
Nikprodanov
Post by Nikprodanov »
Just select the seam on one side, then use "Select Mirror" to select the other side and mark the seam. You can find "Select Mirror" in the spacebar search menu.
