Newbie question: How to close a hole in a mesh...
lexe
Post by lexe » Thu Aug 04, 2011 9:36 am
In 3Dmax I used to be able to draw verteces clockwise to close a hole in a mesh. I'd like to find the same tool / Shortcuts for blender. :oops:
There are so many usefull tutorials out there, but I haven't found my answer yet.
ryanrpv77
Re: Newbie question: How to close a hole in a mesh...
Post by ryanrpv77 » Thu Aug 04, 2011 9:42 am
lexe wrote:In 3Dmax I used to be able to draw verteces clockwise to close a hole in a mesh. I'd like to find the same tool / Shortcuts for blender. :oops:
I'm a newbie myself, I normally use the 'make face' tool. Select 4 vertices and press F. Hope this helps
lexe
Post by lexe » Thu Aug 04, 2011 11:04 pm
Now I'm trying to do a subtract a cylinder from a key(mesh),
i'm getting artifacts where the hole should be,
:shock: Any tips :(
Edit: I guess I'll do it manually then, it'll be faster anyway :roll:
(thanks for the last reply, it really helped)
Skaruts
Post by Skaruts » Wed Aug 17, 2011 10:43 pm
Boolean carving usualy leaves you with some cleaning work to do. this is because blender has to subdivide certain edges to create the intended shapes on the whole. This will probably create a lot of triangles for you to clean, and a lot of vertices to merge, and stuff like that. It's not a bad thing, it's just a bit troublesome. I had to use it to make the mouth of a chess Bishop I once modeled. Was a real pain, though. :)
That's one option. But you have several other options.
You can create a circle with enough sides to fit your mesh perfectly, so that you can then snap the mesh's vertices to the circle's vertices. This is more useful to rounded surfaces (using the shrink-wrap modifier), where there's other things to consider, but you can use it for this with great results anyway. Just remember that you must prepare the mesh and also make the circle have just the right number of sides to fit the mesh.
You can use the To Sphere tool. The To Sphere tool moves vertices to form a circle, but if the vertices aren't perfectly aligned and with the same distance between each other the resulting circle won't be perfect (though it can look like it is).
Or you can do it by manualy adjusting vertices. but personaly I'd prefer to go through a bit of more work to make it look as great as it possibly can. But that's me, I'm a perfectionist. :)
